Results 1 to 26 of 26
    Junior Member Two Rings catmr's Avatar
    Nov 11 2015
    Montreal, Canada
    RS5 Capristo loud in comfort mode? (FIXED)
    Hello!
    I had a couple of questions for you guys
    I just bought a used resonated Capristo system (long story short, the guy had it for a year but he is returning his car to do dealer to get a GLE AMG, so I offered I'm to part out his Capristo system and he said yes).
    First impression, sound great in dynamic! Only issue is that the 2013 RS5 closes the valve at low speed even in dynamic to reduce to drone, so I have to unplugged the valve system in the trunk to really get the full sound. Anyone knows if it's possible to always let the valves open in dynamic with Vagcom or something?
    Like I said, sound is great, but I know that you can get a non-resonated version of the Capristo that sound more ''exotic''. So I was thinking maybe removing the center section and just get a shop to instal me two stainless steel pipe instead (from what I understand, that will give me exactly the same sound as the non-resonated version since I don't think there's any difference with the rear mufflers). BUT, my concern is that, even now, the system is pretty loud even in comfort mode! I read couple of posts saying that closed valves with the Capristo sounded like open valves with sport exhaust but to me it's much louder! And when I switch from close to open with the Capristo, it sounds basically the same to me (maybe a little variation but not much from inside the car, and I can see the valves closing and opening so they are not stuck in one position).
    On the other hand, no drone at highway speed either with closed or opened valves.
    So I am a little scared that, if I go with the mid-resonator delete, it will sound to loud in comfort mode. Also notice that when the valve are opened, the back section is a straight pipe. So that means that if I remove the resonator, the only thing that changes the sound is the stock downpipes, everything else is just an empty tube. Is that really the case with the non-resonated version?
    Still happy with my purchase! I was just not expecting it to be as loud in comfort mode.
    Here's some pics and I KNOW, the car is dirty as hell but it's still winter in Canada haha
    Jul 25 2011
    awesome pickup, I wish i found that listing before you
    I would say go for the awe non resonated downpipes. it sounds insane and you won't need to hack up that capristo
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    I have the stock sport exhaust and my valves stay open in Dynamic mode (2013 RS5). Keep in mind that the powertrain is only in Dynamic mode if the transmission is in S, otherwise the powertrain is in Auto mode and then the valves are closed below 3800 rpm. If you use manual mode, make sure you put the transmission in S first, otherwise the powertrain stays in Auto mode.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Nov 11 2015
    Montreal, Canada
    Quote Originally Posted by Beast View Post
    Haha happy I found it!
    But the capristo is actually two pieces, so you can remove the resonator without cutting anything! Heard that you can get drone by changing the downpipes
    Nov 11 2015
    Montreal, Canada
    Quote Originally Posted by superswiss View Post
    I know that the system automaticly reverse to auto when you start the car, but when I unplugged the flaps from my stock exhaust, It sounded louder than the dynamic mode from lets say 2 000 to 3 500 rpm and especially when downshifting at low speed. I also saw in an another thread that sometimes the valves close even in dynamic (except for 2014+ RS5 because they the select the "engine sound" in the individual mode which keeps the flaps open)
    Jan 07 2013
    Quote Originally Posted by catmr View Post
    Yeah, not sure what to tell you. Mine stay definitely open. If the transmission is in D the exhaust gets instantly louder at 3800 rpm and quieter below that. That's not the case if I'm in S. If I'm sitting idle in S and then switch to D, the exhaust also instantly gets quiet or if I switch to S from D it gets louder. Maybe unplugging the vacuum hose opens the valves a tad wider, I don't know, I never tried.
    Jul 25 2011
    check this out:
    Nov 11 2015
    Montreal, Canada
    check this out:
    Haha this is crazy! Don't tempt me!
    Active Member Two Rings vexa27's Avatar
    Sep 23 2015
    Boston
    Would highly recommend it if you want something truly crazy.
    2014 Sepang Blue Audi RS 5
    Capristo | AWE Non Res Downpipes | CF Side Mirrors | Ecodes
    Instagram
    Nov 11 2015
    Montreal, Canada
    Quote Originally Posted by vexa27 View Post
    I'm just scared that it will sound super loud in comfort mode.
    I don't know if it's just me but even with just the resonated capristo, it's loud with valves closed. And opening the valves doesn't make a big difference.
    Was it the same with yours at the beggining? (with stock downpipes)
    I think this video is from you as well, is that only the Capristo but the version without the resonator?
    Veteran Member Three Rings Johnhanson's Avatar
    Oct 26 2013
    Regina
    Sounds like you are just in default exhaust flap mode all the time. Even when you are in dynamic (or individual with dynamic for engine/trans) it will behave as comfort unless you cycle through the drive select after every startup.
    On mine, I drive in dynamic all the time, but since I added my intake I'll often not cycle through and essentially leave the exhaust I comfort mode (which you are experiencing) to enjoy the smooth deep Intake sound more in the low revs.
    Try cycling through the settings back to dynamic and the valves should stay permanently open - to me the capristo is at its best down low in the rev range - a mellow baritone with lazy driving 2-4K rpm - and you are very much missing out on this part of the capristo experience.
    2013 Audi RS5 Coupe | Phantom Black | Everything except ceramics | Capristo | Eventuri | 15/10 H&R | Rotors when it's cold | V-Spokes when it's warm
    2015 BMW X5 35d Msport | it runs on kerosene | notsport | baby seat
    dead and gone.....
    2012 BMW X6 50i | it had a bike rack
    2010 Ram 1500 | hhhhemi
    2008 Mazda RX-8 | it go-karts
    2006 Infiniti G35 coupe | my lady
    1998 Eagle Talon esi | no turbo powers
    Oct 26 2013
    Regina
    It's a long read but I wrote a pretty detailed review when I went from AWE to capristo. You're clearly missing my favourite part of the exhaust (valves open low revs).
    AWE to Capristo
    http://www.audizine.com/forum/showthread.php?t=622533
    dead and gone.....
    Established Member Two Rings Mlaudisa's Avatar
    Jun 06 2015
    Toronto, Canada
    Well, I just ordered a Capristo and based on Johnhanson's recommendation, will not delete the resonator. I'm looking forward to it and will post impressions once installed... It's a steep price to pay for sound (Canadians get hit with a brutal exchange, duties, etc.), but I wanted to give the car more presence and this is an easy way to do it.
    Active Member Two Rings Lummi's Avatar
    Apr 24 2011
    Austria
    mine with "normal" Capristo:
    https://www.youtube.com/watch?v=JeObyEyZmrU
    second vid with valves open and closed:
    https://www.youtube.com/watch?v=gVH4LWrFFyQ
    and last vid with deleted mid-resonator.
    https://www.youtube.com/watch?v=RyTXZUIXCZE
    i also have the original remote from Capristo to open/close the valves when i want.
    Veteran Member Three Rings patmusk's Avatar
    Mar 27 2014
    2013 Audi RS5, 2013 Subaru BRZ, 1971 Volvo P1800
    Central NJ - USA
    I cycle through the drive select every time I start the car to make sure those flaps are open. It annoyed me at first... but I take my time before pulling away anyway...
    as mentioned here, you definitely want those flaps open before rolling off, as that low-range, light throttle sound is delicious. I am still debating the center delete, but I'm so happy with sound as-is that I haven't made a move yet.
    2013 Audi RS5
    Daytona Grey | Black | MMI | B&O | Capristo Exhaust w/ Non-Res DPs | Eventuri Intake | H&R Coil Overs | Alu Kreuz | EC Sways | E-Codes | V1 | Llumar 35%
    Summer: 20x10 BBS CI-R | Winter: 19x9 Forged OEM | BBS Spacers 10mm~5mm
    Build Thread :: Instagram
    Nov 11 2015
    Montreal, Canada
    Yes I always cycle through the drive select to open the flaps! Love the sound at low revs!
    But when i'm in close the flaps, I was expecting it to be quieter because to me, it sounds really close to open. I'm not really complaining about the noise, I was just surprise and wondering if other Capristo owner felt the same
    2013 Rs5 - Capristo | ECS
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Have you visually checked the flaps are closed? I thought there was a noticeable difference between open and closed.
    Nov 11 2015
    Montreal, Canada
    Yes I've check the flaps and everything works fine!
    I might try to do a video but I don't have a decent recorder, just my phone
    The exhaust is about a year old, so maybe with time the closed valves gets louder?
    Mar 27 2014
    Central NJ - USA
    I def think it remains quiet enough with flaps closed/comfort mode.
    2013 Audi RS5
    Veteran Member Three Rings PEM's Avatar
    Jul 17 2014
    NoVA
    The difference for me is night and day between closed and open.
    Oct 26 2013
    Regina
    Quote Originally Posted by PEM View Post
    Same. It's perfect.
    dead and gone.....
    Senior Member Three Rings AirmattRS5's Avatar
    Jun 05 2014
    Irvine
    You have Nate's old car? You removed that wrap too? =(
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    check this out:
    dude woah....is that yours?
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Oct 26 2013
    Regina
    Quote Originally Posted by chrissurfr View Post
    Jesus just saw that. Makes me cringe. At least let it warm up for 10 seconds!
    dead and gone.....
    Jul 25 2011
    not mine lol, found it on youtube
    Nov 11 2015
    Montreal, Canada
    I brought back the car to the guy who installed my exhaust and found out that the 4 bolts holding the downpipe and the Capristo together were gone! (Probably didn't tight them enough)
    I was getting a pretty good leak, which explains the loudenest in comfort mode. NOW it's much more quiet with closed valves and sound like open valves with the sport exhaust (which is good!). Still has a nice rumble in dynamic and I can now hear a bigger difference between closed and opened.
    Much happier with the sound now!! Thanks for the help guys
