Results 1 to 10 of 10
    Jul 27 2015
    North Bend, WA
    Question regarding tires
    Hey all,
    So I've been looking around for a set of used S4/S5 wheels and may have found a pair, but the cost of the wheels alone puts me close to my budget for wheels and tires. Would I be risking anything by purchasing two different pairs of used tires with similar tread left? Ex. 80% and 60-70%, all season, and same size all around? I've looked around and I've read that different sized tires can put the differential at risk, which is obviously not something I want to do, but it seemed to be in situations much worse than slightly different tread %.
    2018 S3 - Premium Plus
    Vegas Yellow / Tech Package / Black Optics / S Sport Seats / B&O / Resonator Delete
    Jul 27 2015
    North Bend, WA
    Eh, I think after a little more research, I've probably figured this out: Get 4 of the same tires lol. If anyone wants to chime in and confirm though, that'd be great!
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    4 tyres all the same :)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    I have a set of Dunlop SportMaxx GT's for sale. New take offs from my S5. Link to my ad is in my sig. I am in Vancouver BC. Not sure how you feel about driving up here and picking them up.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    could always get replicas http://hartmannwheels.com/audi-wheels
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    If you do get different tires make sure they are no more than 2/32 different in tread depth. That is the max you want to go. When I worked for Ford we saw a lot of issues with this and the AWD explorers and Lincoln and mercery equivalent models. It would destroy both diffs and if kept driving it would destroy the center transfer case diff. What happens is that you cause the front and rear wheels to turn at different speeds. and the center diff instead of spinning all together starts to walk around with the pinions and constant spinning of the pinion/ spider gears causes excessive wear and tear. And its amplified since there are no bearings that they ride on and are not ment to be spinning all the time.
    Well I don't know what your tire situation is now. But pick up the rims and wait a little bit to save up some money and then buy tires. Unless you need tires asap. But try to get 4 of the same tires if you can
    Oct 20 2008
    Bloomfield Hills, MI
    Besides wearing differently, some other differences:
    Rolling diameter differences: Even though two different tires are of the same spec, they may have different circumferences when inflated.
    Traction variations: Every type of tire will have different limits of traction, also dependent upon wet, dry, temp, etc...your front tire could grip better in the wet than the rear which could lead to sudden oversteer. You never know - therefore if I had to get different tires on the same car, I would never push the car even remotely hard. What's the point of having this car then.
    Don't mix up different tires on a car, unless it's a daily beater that you don't care about.
    E90 M3 6MT - Melbourne Red
    (Sold) 2013 S4 - Glacier White / Black
    Jul 27 2015
    North Bend, WA
    Thanks for the input, guys!
    So yeah, it sounds like I'm taking a risk by getting two different brands of tires despite being the same "size". I called the used tire place and it turns out they have 4 of the same tires with 60-70% tread depth left. I mentioned the same issue I explained to y'all and he had the exact same thing to say, and all stated he wouldn't feel comfortable selling me two different brand of tires.
    @plat: Thanks for the offer, but I actually wouldn't even be able to get into BC because I don't have a passport, haha. They're also quite a bit out of my price range :)
    Senior Member Two Rings mavz's Avatar
    Apr 06 2015
    Just hold off until you can do it properly... also don't waste your money on crap tires :)
    Gone: 2013 Estoril S4
    APR - AWE - Vorsteiner - Continental - ECS - Akebono - JHM
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by doomislegend View Post
    No problem
