Results 1 to 9 of 9
    Established Member Two Rings theSaint024's Avatar
    Jul 16 2014
    SF CA
    Advice wanted. Akebono pad replacement withOUT new rotors?
    Title says it all. I have 25k on my AR with stock pads. Pads actually look pretty thick still, like new-thick. I am finally fed up with the dust and want to swap in Akebonos on the fronts for now, probably backs later after I do some unscientific testing on the dust difference. Question is, is there any issue not changing out the rotors at the same time? If my pads were worn low, I would change the rotors too, but apparently I drive very gingerly most of the time - due to shitty city roads. I've changed out pads before without rotors on other cars, usually changing the rotors every 2 times I change the pads. Rotors also feel fine to the touch, no uneven wear, no significant lip. Any issue with my case since miles are low and current pads looks pretty full? Anyone done this? It's not real clear in the brake discussions I've searched through.
    2013 allroad - ibis white P+ - The answer is... "it's an allroad bro."
    Established Member Two Rings inv3rtig0's Avatar
    Oct 22 2014
    1976 Toyota Celica GT
    Paso Robles, CA
    I did exactly this and have zero problems. Same situation, rotors were in fine condition, shop did not recommend a replacement, so I didn't bother. Went from stock pads to Akebono. You'll be happy you did, that dust was outrageous.
    2010 A4 Quattro Prestige 6MT S-line | build thread
    Revo stage 2 | 034 HFC | AWE Quad exhaust + downpipe | 034 trans mount insert | interior LEDs | ECS short throw shifter
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I've changed pads only many times on various cars over the years with no problems.
    2011 A4 Avant
    Jul 16 2014
    SF CA
    Thanks guys. I was just confirming no issues specific to the stock pads, rotors, or system with this car. Will order the akebonos asap.
    Jan 24 2012
    Tucson AZ
    I have a near-new (see pics) of Akebono ($50 + shipping) and used Carbotech track pads for sale. See classified:
    http://www.audizine.com/forum/showth...2#post11497302
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    If your rotors are completely flat (rare), then sure. Otherwise have them machined to smooth them out. This way you maximize surface contact area.
    I switched to Akebono pads (along with new rotors) and I love how my rims stay clean!
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Most people will tell you that you will need to at least resurface the rotors when installing new pads so it will bed correctly. I have done it both ways and I think as long as the rotors dont have a lip on them, you should be fine. If you can feel a lip on the outer edge, I would have them resurfaced.
    2024 RS3 Kemora Gray
    Senior Member Three Rings redge2.7t's Avatar
    Jun 24 2010
    VW Atlas
    Folsom
    I did exactly this as well, Akebono pads and all. The dust difference was shockingly dramatic! You will be very happy with the results!
    Current- Vesuvius Grey C8 S6 Prestige- APR Carbon Intake, APR Tune, ECS Spacers
    Former- Quartz Grey B8 A4 Avant_Prestige_S-line_(1 of 7) REVO Tune, aFe, ECS TIP, RS4 Grill
    Former- Stage 3- C5 A6_too many mods to list.
    Jul 16 2014
    SF CA
    Pads already on their way. Can't wait for clean wheels lasting more than 2 days. No doubt that rears will be changed soon as well. I'm pretty sure I know the results of my experiment already.
