    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Wheel Bolt Recommendations
    TL;DR: Does anyone have recommendations for high quality, longer wheel bolts to use with spacers? I don't want to spend hundreds of dollars for Tikore though.
    Long: So when a tech went to install my spacers they didn't thread the bolts in by hand, but rather ran them in with the air gun. This caused the threads to get jacked up on a couple bolts. These were the bolts that came with my ECS spacers. I'm thinking they aren't as strong of metal as the stock ones (edit: shouldn't assume this, it was 100% the mechanic's fault) so I'm looking for a potential better replacement. Anyone have any recommendations?
    PFA:
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Oct 02 2006
    Wadsworth,OH
    We've never had any issues with bolt strength. They are made to the same strength as OEM. Your mechanic should pay closer attention before he destroys some wheel bolts and possibly cross threading your hubs by carelessly blasting them in with his air gun.
    Jason
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Quote Originally Posted by MileMan402 View Post
    We have European made bolts from Hartmann available
    Hartmann R13 ball seat lug bolts at Achtuning
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I liked the two piece design of the OE bolts so I went with RAD or Otis inc. they have several lengths.
    http://otisincla.com/index.php?route...16_224_229_231
    Two piece is probably not strictly necessary though.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 14 2012
    PHL | BOS | SEA
    Jason
    Sorry Jason, I shouldn't have made that assumption. It definitely wouldn't have happened if he had properly threaded them by hand. And I love my ECS spacer kit other than that; I guess I was just stressed when I typed that because I want to get my summers mounted.
    I've long since thrown out the bags the bolts came in, what length do you recommend for 10mm and 15mm spacers respectively? nevermind found it on your site
    Quote Originally Posted by Skyler@Achtuning View Post
    We have bolts from H&R and Hartmann available, both are European made with exception of the "Value Line"
    http://shop.achtuning.com/search.aspx?find=bolt
    Quote Originally Posted by gk1 View Post
    Thanks guys I'll take a look at these too.
    2014 S6 - SOLD
