Results 1 to 9 of 9
    Veteran Member Three Rings gesTTalt's Avatar
    Oct 10 2004
    Tracking down high rpm misfire in cylinder 6 only
    I need to check one of my coils is receiving signal. I'm chasing down high rpm misfire in cylinder 6. Things I've tried already:
    Swapped coils, but misfired stayed. These are new coils.
    Changed the plug - looks darker, like sooty compared to my other plugs.
    Injectors are all cleaned and tested
    ST and LT fuel trims look good
    Symptoms started a couple of weeks ago after doing some runs. Misfire only happens at high rpm or wot. I just put the car back together after cleaning the injectors, and they were pretty dirty. All is good now. I should have swapped cyl 6 injector, but since they were cleaned, didn't think I needed to switch it.
    I'll be doing a compression test this weekend, as well as reducing the gap in the cylinder. When I have time, I will also do a carbon clean (about 15k since last carbon clean)
    I have a volt meter, wondering what I should be looking for?
    UPDATE 4/1/16
    bumping this, hoping to get more input. Misfire started weeks ago when doing some runs with friends. Misfire in Cylinder 6 continues, only at WOT or heavy load past 4500rpm
    Here's what I've done:
    New coils, even swapped cylinders 1-4 with 5-6
    New spark plugs, gapped smaller from .0032 to .0026
    Cleaned and flow tests injectors
    ST and LT fuel trims look good still
    HP fuel at rail is at requested at WOT
    Compression, with enige slightly warm from moving the car, is at 170 across all cylinders
    I have not carbon cleaned since 80k, now at 96k. Last thing I can do is carbon clean, which I can't do for a couple of weeks.
    Car runs fine at part throttle. No DTC other than the misfire in Cylinder 6. I can keep the DTC from logging if I don't go WOT. Also, can rev past 4500 rpm without setting of the misfire, so long as I am not going WOT. It does not misfire in any other cylinder.
    07 Daytona Grey RS4
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    Are you getting any codes?
    Oct 10 2004
    I can make it throw a misfire code if I go wot enough. Car is drivable without going wot or staying above 4500 rpm. I don't want to cause any damage with it misfiring. I don't think is leaning out, which is good.
    07 Daytona Grey RS4
    Oct 02 2015
    B7 RS4, UrS4
    Boston
    Is it a random misfire or is it consistently in one cylinder? Edit: saw cylinder 6. If you have access to Vagcom you can log fuel trim and spark advance, that might help if you have access to a vagcom. Although I'm not much use with wiring. Never liked it.
    Oct 10 2004
    Bumping for any other input. I updated the top thread
    07 Daytona Grey RS4
    Jun 18 2009
    Phoenix, AZ
    Any codes in VCDS?
    Do some runs and log fuel rail pressures. I had to replace my HPFP's after getting a misfire at anything more than partial throttle.
    2017 Camaro SS 1LE
    Oct 10 2004
    Quote Originally Posted by FWP! View Post
    Any codes in VCDS?
    HP fuel rail pressures requested and actual are spot on. Aside from the misfire DTC, nothing else. I can keep the DTC from logging as long as I don't go WOT for too long.
    07 Daytona Grey RS4
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    gesTTalt, I'm thinking it may be a problem with the injector in cylinder 6 since the misfires are only happening at WOT. Maybe the injectors were not tested at the correct duty cycle that would be experienced during WOT. The injectors at WOT should be at 80-90% duty unless the tune with your blower is causing them to push beyond that.
    Can you scope the cylinder to rule out strange carbon buildup or cylinder wall damage first? Be careful with your testing, WOT is the worst time to have misfires going on.
    Edit: I guess that seems unlikely given you didn't have any misfires before and you only had these injectors cleaned. Seems like a tough problem to troubleshoot.
    Oct 10 2004
    Quote Originally Posted by komseh View Post
    I'm troubleshooting all the possible scenarios. I'll get a new injector when I carbon clean and see if that will remedy the problem. After the carbon clean and new injector, I may need to get some help.
    07 Daytona Grey RS4
