Results 1 to 10 of 10
    May 28 2014
    East Coast
    RS7 Braking Options and Questions
    Hi guys,
    I have a 2015 RS7. Every 4-6k miles or so I seem to run out of brakes. I do drive it hard, and rarely track it. That being said it is $4200 to have the brakes done at the dealer, and around $2000 to have it done elsewhere with OEM parts, this includes rotors and pads. The OEM brakes and rotors I keep replacing start vibrating and become noisy after 1k miles. Therefore I kind of want to go with a fuck it option and see what happens. After all if I spend $200 on pads, and they suck, I can just go back to the $4200 set. If they are ok, I have just saved $4k. Quite the return on the gamble... I don't have $30,000 to spend on ceramic brakes, which leaves me with my final question:
    What after market pads can you recommend and/or rotors that may alleviate the extremely quick wear of my current brakes. Also, I am just going to do a pad slap without replacing the rotor, because yolo, lets see what happens. Worse case scenario the car is messed up for 4k miles or 1 month (if it's that bad I'll bring it sooner). Any suggestions?
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Brother, RS7 or no RS7, needing pads and rotors every 4-6k miles is nuts. Do you have a breakdown from the dealer on how much of that is parts? Are RS7 owners limited to the "waffle" looking rotors, or is there a less expensive option? Is it possible that something is causing your rotors to warp (I had assumed warped rotors was a thing of the past with modern compounds, but vibrating used to be a sure sign of warped rotors)? I'm not sure the pads are your problem here, but perhaps a reputable ceramic pad might net you a few more thousand miles?
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    May 28 2014
    East Coast
    Hi Brooklyn,
    I know, I do a lot of 190-60mph stops. I agree that it has gotten excessive. Hence why I am looking to change. Its a bit suspicious since my first set got 12k miles after that only 4k. I have has brake jobs done at 2 seperate dealers, and many techs have said no problem with brakes, but they may just be trying to sell more brakes... Any ideas on what it could be?
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by s6driver View Post
    Wow! Where?
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    May 28 2014
    East Coast
    I do a lot of cross country rallys. So pretty much anywhere and everywhere... Except VA they are nuts.
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    Upgrade to the ceramic off the plus model, they will last much longer and handle the heat better
    Sent from my SM-G935V using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    May 28 2014
    East Coast
    Quote Originally Posted by sciblades View Post
    The upgrade cost of the $30,000 makes it more affordable to just purchase a new car. Try again.
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Europrice has them for almost half of that, something like 17-18k. if you factor in how many times you've swapped brakes already you would almost have a full set by now. and that 18k gets you full setup front and rear
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    May 28 2014
    East Coast
    Nice thanks for the referral over. Still have to get them installed putting me at $19k. For $19k I can pay the difference between the new RS7 and the old one that comes with it still. It sounds like the inefficient crappy brakes need to either be replaced with a new car. I am going to try experimenting with an audi tech and see if we can get the regular brakes to be better. I find it a little weird that Audi would make a car like this with such crap brakes.
    Senior Member Three Rings carymac's Avatar
    Jan 14 2014
    2014 RS7
    Miami, FL
    Wow and I thought I drove aggressive. I just replaced pads at rotors at 36k. My rotors lasted until now and only changed pads once at about 11k. Honestly just by looking at the oem replacements, they don't seem to be the same quality as the one that originally came on the car.
    IG - @sxty3
    2016 Florett Silver SQ5
    2014 Suzuka Grey RS7 - SOLD
