Results 1 to 36 of 36
    Senior Member Two Rings mprivi's Avatar
    May 26 2015
    2002 B6 A4 3.0 Project
    Long Island, NY
    Control Arm Quality
    It seems my lower control arm bushing is cracked. My mechanic said to just get a whole kit and replace all at the same time as they are original 2002 95k mile control arms. I have been trolling all the control arm threads and I was going to go with the FCP option 3 kit but seems that the quality isn't there. The FCP warranty seems great, but i'm sure there is fine print everywhere. The OEM ones cost as much as the value of my car. I was wondering if anyone can point me in a direction of an affordable yet quality control arm kit.
    I am also looking to get a set of coilovers, since my suspicion is original, while the control arms are being changed. Either Soloworks, Streetedge or ST... What set of coilovers and control arms would work with in a reasonable price?
    Thanks in advance.
    Aug 27 2013
    Philly
    Quote Originally Posted by mprivi View Post
    Thanks in advance.
    FCP warranty is actually as good as it sounds. Have an issue, call them up, the send a whole new kit, you send back the old stuff. FCP is an awesome company and really stands behind everything they sell.
    May 26 2015
    Long Island, NY
    Quote Originally Posted by SJorge3442 View Post
    Are you running the FCP? What has been the lifespan of yours? I'm also 3.0L
    Aug 27 2013
    Philly
    Yeah I have the FPC kit. I have about 8k miles on them and so far so good.
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    I've bought things from FCP for a long time even when I was working on the old Volvo and they're pretty good. I also have the FCP control arms on my Audi A4 3.0 Quattro that I swapped out a little over a year ago. The only thing I didn't like were the Karlyn replacement end links.
    Aug 26 2005
    Checkout MOOG for excellent quality chassis parts at a good price.
    http://www.moogparts.com/find-my-part.html
    Vorsprung durch Technik
    Apr 15 2014
    Ottawa/Gatineau Canada
    No experience with Moog on a B6, however, I ran a few suspension parts on my B4 that were Moog and they were totoal junk with quick failure.
    Established Member Two Rings Europotvin's Avatar
    Feb 03 2015
    Sherbrooke Quebec
    I will be installing my FCP control arm kit this weekend, I will post up once installed !
    APE - Automotive Performance Engineering http://automotiveperformanceengineering.com
    A4 B6 TDI 6spd
    BUILD THREAD: http://www.audizine.com/forum/showth...o-Diesel-Build
    INSTAGRAM: euro.po
    Aug 27 2013
    Philly
    Quote Originally Posted by Europotvin View Post
    Lets hope your pinch bolt isnt frozen! If its not, this job isnt bad at all. Can probably get done in about 4 hours on the ground, if the pinch bolt doesnt put up a fight.
    Feb 03 2015
    Sherbrooke Quebec
    I know one side will be ok since my knuckle was changed last year, but Im hoping for the best on the other side. I will be armed with cans of PBBlaster, Mapgas and lots of patience lol
    A4 B6 TDI 6spd
    INSTAGRAM: euro.po
    Aug 27 2013
    Philly
    Throw a impact gun on that list and you should be fine. I soaked mine in blaster once a week for a few weeks leading up to the job. Then I heated the knuckle and just hit the bolt with my impact and it came right out. It put up a little fit, but this is definitely one of those bolts that needs an impact on it. You need to be able to spin it fast.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i wouldnt cheap out on cont arms. i bought a brand new set of febi's and they lasted a year. replaced with TRW's and they were much better.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Hard to say on a limited sample... I never put any penetrating oil on mine and took it out with a wrench; it also came right out. A set i have from the salvage yard were attempted using an impact and stuck. I got them with the arms still in them since they couldn't get the bolt out. Others have had shops snap them off with a gun.
    Also, I have used Febi in the past. After 40,000 miles I had one arm fail at the ball joint. Somehow, water got past the seal. The rest of the arms were perfect. My current Febi's seem decent, but I don't have many miles (2500)on them. They were made in Germany and looked to be decent parts.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I had the boots fail on my FCP lowers after a little under 100k miles. The boots on the free replacement arms look like a different sturdier material. Pinch bolt tips: Clicky click®
    May 26 2015
    Long Island, NY
    So it's kind of hit or miss with what brand to get? I have been reading reviews on most brands and some people have good and bad luck with the fcp as well as the febi and melye hd kits.
    Aug 27 2013
    Philly
    Improper installation is usually the biggest problem for control arms. So many people forget to torque at ride height. This causes the bushings to wear out so fast. The fact that Old Guy got just about 100k on a set of FCP arms should tell you something.
    May 26 2015
    Long Island, NY
    Ok I hope my mechanic knows to torque at ride height... Also will prob do coilovers at the same time will this make it more difficult?
    Aug 27 2013
    Philly
    Nope. The coil overs shouldnt add any additional level of difficulty.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    I did the FCP kit and ST coils at the same time and no issues after 60k miles.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Same as ^^^. got 18k or so on them now. still looking great.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    May 26 2015
    Long Island, NY
    Quote Originally Posted by chris@fifteen52 View Post
    That's the setup I was looking at. Any input on Solowerks S1 or Streetedge coils? Just looking for stock sport setup at about 25/25.5 Fender to ground don't want to rub
    Oct 04 2012
    Everywhere
    I love my STs I have them set very high
    Aug 26 2005
    Quote Originally Posted by Luxus Panzer View Post
    I don't know if the B4 parts are necessarily comparable to the B6 parts. I have used MOOG parts on other cars, assume the Audi replacement parts would be similar.
    What specific suspension parts have you had bad experience with?
    May 26 2015
    Long Island, NY
    there's a local guy with a used set 2k miles on them for 600$ is that a good price used or more like 500$? I know new they are 750-850
    Oct 02 2006
    Wadsworth,OH
    I'll likely need to do control arms in the next year or so and the kit I plan to install is the Vaico kit below.
    Proper control arm installation is key for long bushing life. Believe it or not improper installs really can cut the life span of the bushings down substantially.
    Jason
    Oct 04 2012
    Everywhere
    With a used set you never really know the mileage, no warranty and make sure they are the Avant specific kit. For not much more you can get a new set with a 5 year warranty.
    May 26 2015
    Long Island, NY
    The 5 year warranty i guess is worth the extra cash. I don't have an Avant is there a reason I would need that set? I have a 2002 3.0L Sedan Quattro
    Apr 15 2014
    B4 tie rod ends and Sway bar links. Both were total crap. I had one sway bar link sheer off at the weld with under 500KM on it.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Oct 04 2012
    Everywhere
    No I thought you had an avant. I think you PM'ed me the other day about the STs.
    May 26 2015
    Long Island, NY
    Yes I did for a price on the ST's... My other option would be skip the coilovers as I really don't need adjustment, Im just looking for a nice 25-25.5" ride height, and go with bilstien and H&R spring setup.
    Oct 04 2012
    Everywhere
    The Bilstein/H&R combo probably costs the same or more, no adjustability, not sure if they have a warranty and the Shocks are not made and designed for the springs. I set my height and haven't touched it since.
    Veteran Member Three Rings shokwav09's Avatar
    Jul 26 2009
    hhr, 2013 rs5
    kansas city, missouri
    is the majority concern the bushings? cause im in the middle of replacing all of my arms with performance urethane bushings. the only setback ive crossed happens to be the front lower rear curved control arm ball joint. it looks factory pressed in and there dont seem to be replacements for it. if i have to buy new arms just for new ball joints to use aftermarket bushings i will, but its kind of a jip from audi if thats the case. either way, if the ball joints still good the lowest cost method is urethanes pressed in.
    I wanna do a burnout at heavens gate in an audi
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by shokwav09 View Post
    TRW is the OEM for these. JTC350 & JTC348, summit has the best price I could find, $150 for the pair. in the middle of an entire suspension replacement myself.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jul 26 2009
    hhr, 2013 rs5
    those part numbers didn't match my rs5 arms. It's all good. I've been eyeballing some prices anyway. the fun part is when I buy a hydraulic press and put them in myself. make sure you dont pull your inner sleeve in the spindle when you get the ball joints out. You'll have to buy a whole new/used spindle if you do. use a ball joint separator!! id seriously upgrade to superpros and manual labor or 034 track density either way. huge difference in handling and bushing longevity.
    Mar 25 2015
    Placer County
    sir this is the b6 a4 forum
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jul 26 2009
    hhr, 2013 rs5
    dang. lol.
