Results 1 to 10 of 10
Thread: EPC light ?!
    Established Member Two Rings Axxenice's Avatar
    Dec 29 2014
    Sweden
    EPC light ?!
    Hello!
    The EPC light just lit up while driving and i can only rev to 6500rpm. No MIL yet.
    Anyone know whats wrong?
    Skickat från min LG-H815 via Tapatalk
    Established Member Two Rings mk420thae's Avatar
    Sep 22 2009
    Lexington
    Probably intake runner faults
    Sent from my SM-G900P using Tapatalk
    JHM tuned Avus Silver RS4
    Dec 29 2014
    Sweden
    And now it went away, could it be carbon build-up or something like that. I've been driving it like a pussy this winter, short drives to work and such.
    Oct 11 2007
    Suburbia
    get a clean, when was the last time?
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Mar 11 2008
    B7RS4 & e46Ms
    So, when you see an EPC light...probably don't rev the motor to 6500. More like turn the car off and restart it in hopes it resets. Ideally just park it and fix it. Don't drive it like that.
    FRRG AZ Ring
    Dec 29 2014
    Sweden
    Quote Originally Posted by WinterRunner View Post
    It was cleaned 20000miles ago if i remember correctly.
    Dec 29 2014
    Sweden
    Yes ofcourse, i did restart it and it disappeared. It runs like normal now, kick at 5500rpm still present.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Probably cold carbon gumming up the flap shaft movement then.
    Oct 11 2007
    Suburbia
    20K is the furthest Id go without a clean. You're due....
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by mk420thae View Post
    This, or it's one of the flap position sensors. I had that light go on/off a few times over a few days but after a scan with VAG COM, it was the passenger side (bank 1) intake manifold flap position sensor. I replaced it and haven't had the issue since.
    2017 Camaro SS 1LE
