Results 1 to 18 of 18
    Established Member Two Rings hacgumyu's Avatar
    Jan 05 2010
    Oil change surprise
    I did my first oil change on my newly acquired 3.2 avant. After took off the splash guard , I saw this cable hanging and the connector end looks like broke off from somewhere. What's this cable hanging under the fan and radiator? How hard is it to repair or replace? I have no fault code and lights showing.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Trace to where it is coming from. If its like the 2.0t it could be the motor mount sensor that people disconnect with aftermarkets.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    I'll take a look for that connector when I get home, if no one has answered by then. I'd check along the radiator could be a temp sensor or something like that. Especially since the wires run back into the bumper area from the looks of it.
    2013 Phantom Black C7 S6 Stage 3 | 2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    IG: tyscalzone
    Mar 01 2013
    Denmark
    Fog light?
    Feb 05 2008
    Kenmore
    Oil change surprise
    Quote Originally Posted by Mikael View Post
    Fog light?
    ^this is probably it. Easy to check too.
    IG: tyscalzone
    Feb 15 2016
    Cambridge,Ontario
    wire looks yellow/brown anyone with a wiring diagram should be able to tell you
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings clumsyme's Avatar
    Jun 12 2013
    Nashville
    Quote Originally Posted by hacgumyu View Post
    I did my first oil change on my newly acquired 3.2 avant. After took off the splash guard , I saw this cable hanging and the connector end looks like broke off from somewhere. What's this cable hanging under the fan and radiator? How hard is it to repair or replace? I have no fault code and lights showing[/IMG]
    I have a 3.2 avant and am doing an oil change tonight I will take a look for that wire. if you havent found an answer by then
    Quote Originally Posted by yeoj112689 View Post
    .... you sure do read good dont you
    "He-Man with that long sexy hair, in those provocative tights with his butt looking oh so scrumptious in those booty huggers." -Seerlah
    Jan 05 2010
    still haven't find answer yet. I can only see it came down from the block where the fan is attach to.
    ps: my fog lights are good on/off ok.
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    Is your horn half as loud?
    Jul 18 2015
    Only reason I ask is because I ripped out a connector for a horn on a BMW when removing the bumper and it looked exactly like that. I think there's 2 horns on the front of the car.
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I have this wire in front of radiator that isnt plug anywhere. Might be the same?
    Envoyé de mon SM-G903W en utilisant Tapatalk
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Senior Member Two Rings mitchell.'s Avatar
    Oct 27 2014
    Toronto, Ontario
    Quote Originally Posted by Mister W View Post
    That's gotta be it
    Drive On, Brother!
    Mar 24 2013
    Oakdale, CT
    ^Ambient temp sensor
    -Adam
    Jul 18 2015
    Is that really where it is? I thought that was the power steering cooler lol
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by clumsyme View Post
    my fault, had just woke up and misread it.
    Jan 05 2010
    I looked behind the front grill, the sensor is missing. that sensor is cheap, but the broken tab on the wire I'm not sure who sells it and what's its part number.. any help?
    Nov 15 2011
    Montreal | I sell in USD
    Tie-wrap.
    *****I sell in USD*****
    Oct 16 2008
    South Florida - Ft Lauderdale
    1J0973702
    Phil
