Hi
I have engine light on..I took few readings but they seem ok including rail pressure in MVB106. Fuel filter replaced.I am not sure what next to do.Has this car got the fuel pump control module under the seat on top of tank? I know we used to have problems with the high pressure pump cam wearing out which affects the high pressure fuel. But i am not sure as reading on 106 seem good at idling. Any hints on this would be appreciated! See diagnosis log:
Monday,21,March,2016,12:44:08:46890
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: License Plate: QUERTIN AUDI A4 DIAG
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 8E0 910 115 P HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0104010A190F0120
Work Shop Code: WSC 01126 444 65050
VCID: 2E58C7A1B9A06F4EDC-807A
5 Faults Found:
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 28
Reset counter: 255
Mileage: 149568 km
Time Indication: 0
Freeze Frame:
RPM: 1904 /min
Load: 36.1 %
Speed: 80.0 km/h
Temperature: 67.0°C
Temperature: 11.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 150192 km
Time Indication: 0
Freeze Frame:
RPM: 357 /min
Load: 79.6 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 63.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.319 V
P0087 - 008 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 150359 km
Time Indication: 0
Freeze Frame:
RPM: 723 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 104.0°C
Temperature: 60.0°C
Voltage: 13.081 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 151056 km
Time Indication: 0
Freeze Frame:
RPM: 1986 /min
Load: 67.8 %
Speed: 41.0 km/h
Temperature: 22.0°C
Temperature: 6.0°C
Voltage: 14.224 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 151056 km
Time Indication: 0
Freeze Frame:
RPM: 1986 /min
Load: 67.8 %
Speed: 41.0 km/h
Temperature: 22.0°C
Temperature: 6.0°C
Voltage: 14.224 V
Readiness: 0000 0000
Address 01: Engine (8E0 910 115 P)
13:05:12 Group 001: General
720 /min Engine Speed (G28)
87.0°C Coolant Temperature (G62)
0.0 % Lambda Control Bank 1
01110111 Basic Setting Requirements
13:05:49 Group 005: General
760 /min Engine Speed (G28)
18.8 % Engine Load
0.0 km/h Vehicle Speed
Idle Load Status
13:06:23 Group 103: Fuel Injection (Fuel Pump Adaptation)
4.88 bar Current Fuel Pressure
96 Fuel Pressure Regulator
2180 Adaptation Value elect. Fuel Pump
ADP. O.K. Fuel Pump Adapt. Status
13:06:39 Group 106: Fuel Injection (Fuel Supply System)
49.87 bar Fuel Rail Pressure (actual)
75.3 % Electric Fuel Pump 1/2
Electric Fuel Pump 3/4
55.00 s Fuel Pump Shut-Off Time
13:06:57 Group 106: Fuel Injection (Fuel Supply System)
50.23 bar Fuel Rail Pressure (actual)
13:06:57 Group 002: General
19.5 % Engine Load
1.02 ms Injection Timing
3.22 g/s Mass Air Flow Sensor (G70)
