Results 1 to 2 of 2
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    Removing Lumbar Switch
    I'm looking to remove my lumbar switch on the drivers side without taking the seat off. I'm pretty sure theres a way to remove the side panel with all the seat controls, but I'd like some advice. Anyone done this? My back thanks you
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    There are 2 screws on the under side of the cowling. You could probably get to them using a 90 degree screw driver. One is towards the front of the cowling and one towards the back. I just replaced my driver's seat cushion so I just did this on the weekend but then again mine is a manual seat not power.
    Doug
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, Frankenturbo F4-H Kit, Bosch EV14 550cc injectors, APR R1 Diverter Valve, Snow Performance Stage 3 Water/Meth Injection Dual Nozzle Setup, Majesty FMIC kit, SSAC Cat Back Exhaust, Podi Boost Gauge in center vent pod, ATP Test Pipe, K&N air filter, HID fog upgrade, eBay short shifter, Center LCD retrofit, Aero wiper kit, Eibach Pro-Kit lowering springs, 18” B6 Ultrasport, Firestone Indy 500.
