My rear wiper does not work. I have verified continuity of the harness between the hatch and the rear compartment to rule out damaged wires at the hatch.
Ground wire is good. When I push the wiper switch all the way forward the pump turns on and I get 12V on the Green/White wire which is what the diagrams says should happen. I can't diagnose much more, but I suspect the other two wires control the intermittent portion. I assume the pump should turn when there is power on green/white, but am not 100% sure.
I am thinking my pump is the issue. I disassembled it. It does not have the common issue of a rusted out inside and everything mores freely.
Any thoughts?
