Results 1 to 9 of 9
    Sep 17 2015
    United States
    need your input/advise/thought in buying the Ross-tech
    hi everyone,
    I currently have 03 A4 B6 3.0L ATM. and my father in law has the VW Jetta 2.0 2002.
    I don't know how long i will keep the Audi A4 B6 but it has be seating for since last summer to now. I has been repair/replace parts on the car to bring it back to life without any scanning tools.
    I need a scanning tool that has instructions and programming capability. after read / ask questions, I am settle for the Ross-tech. I need your help on your thought base on my current vehicles.
    which version of ross-tech hardware i should go with. one big key to keep in mind is that my other half is the fan of Audi after she drove my A4 B6 for 5 years. she does like all the Q7 and A6/S4
    Name Price Availability
    VCDS License with HEX-NET (WiFi/USB) 10 VINs (All VAG) $449.00 In Stock
    VCDS License with HEX-USB+CAN Unlimted VIN (All VAG) $349.00 In Stock
    VCDS License with Micro-CAN Unlimited VIN (most VW '05.5 to current) $249.00 In Stock
    VCDS License with KII-USB Unlimited VIN (VW to ~'05; Audi to ~'03) $249.00 In Stock
    should i get the HEX-NEX 10 VINs? or should I get the KII-USB unlimited VIN? what is 10 VINs and unlimited VIN? is this mean I can only store or work only 10 cars? can I remove the vins so it never be 10 vins in the system?
    upward compatible, hex-nex is sensible to procure however, if i sold my cars and not go with Audi/VW, KII-USB is favorable.
    what is your thought?
    Olivier
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Quote Originally Posted by OlivierA4 View Post
    Yes
    No
    If you think you will be getting more VAG vehicles that are more modern I would go with the HEX-USB+CAN. If not then I would just get the KII-USB.
    Jun 30 2008
    Erie, Pennsylvania
    HEX-USB+CAN is the good stuff. Does everything, unlimited VIN. If you are going to buy one, get the one that does it all so you aren't stuck later. If you are limited to 10 VINs then you can't scan friends cars and stuff. Not cool. Don't be that guy. ;)
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    For B6 and older, you don't need hexcan. But if you plan on buying a 2005+ audi or VW you'll need hexcan.
    The KII+UsB does the same thing but only works on 2005 and older cars.
    Audi Club Bay Area
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    I found a KEY-USB, which is unlimited VIN and works up to '03 Audi, for $100 on Panjo. Check Panjo and eBay, you may find a deal. The license is in the cable, so a genuine cable is all you need for the full version.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Sep 17 2015
    United States
    Quote Originally Posted by cschuster View Post
    i has been looking for this but can not find anywhere. i can buy key-usb then later on if i upgrade my car, i can buy a wireless or hex-net. i checked Panjo and can not find a thing
    Sep 17 2015
    United States
    Quote Originally Posted by Furly View Post
    you sold your about 3 months ago if i remember correctly. i was just into fixing my car with limited knowledge. otherwise :)
    Jun 05 2013
    Lexington, KY
    Yea, you can always sell it to recoup the money. They don't really seem to loose that much value. In a few years you should still be able to get at least $150 for it.
    2011 TTS
    Apr 07 2011
    This
    The deals are there, just have to keep an eye out for them and strike quickly before someone else does.
    This does seem to be the case. The $349 cable still sells for at least $300 on a regular basis around here. If it's any cheaper it's usually because someone is looking for a quick sale.
