Results 1 to 18 of 18
    Veteran Member Three Rings Audimilo's Avatar
    Apr 19 2014
    CO
    2002 B5 S4 Avant 6-Speed MT, Stage 3
    This is a fully sorted B5 Stage 3 Avant 6 speed.
    Aka my daily driver. I Highway commute a lot, so I set this car up to be a highway animal. Car is a high mileage daily driver, that has been completely gone through and built to be reliable, robust, and incredibly fast.
    sitting at 283,000 miles, and has been expertly serviced and maintained.
    Massive folder of receipts.
    *******NOTE: MORE PICTURES THROUGHOUT THREAD******
    Full F21 turbo build, RS4 Stage 3+ 034 Clutch & Flywheel, H&R Suspension, full 3" exhaust & 3" Downpipes, Manifolds and downpipes Swaintech ceramic coated, 034 85mm MAF, FSI Audi R8 coil conversion, Full stage 3+ tune.
    6 Piston Brembo’s, 350mm Cryo’d / Slotted Rotors, Stainless lines, 034 big rear brakes.. EBC pads,
    OEM Audi Timing kit and water pump done, Full reseal with EVERY GASKET & O-Ring Replaced and serviced with AUDI OEM parts, H&R & Bilstien Suspension, Control arms.. the list is a long one.. 18" VMR wheels, brand new Michelin Pilot Sport's,
    Basically, a 6 speed full F21 Avant you can daily and not worry about putting miles on.
    Happy to deliver anywhere in CO, or assist with pickup by a shipper.
    Asking ~ 15k.
    Questions?
    Txt me @ Eight 0 8 2 5 3 Nine Nine 8 2
    email me for further info: rubin565 A T g mail
    Here’s the list:
    Enigne/Drivetrain
    Frankenturbo F21 Turbos
    Frankenturbo Oversize turbo inlets
    Wagner Intercoolers with carbon fiber shrouds
    Bosch EV14 injectors with OEM Audi Injector O-Rings
    034 Motorsports 85mm MAF
    AUTUNING aircraft grade AN stainless Oil feed and AVCS Lines
    Bosch 044 Fuel Pump
    New Audi OEM Fuel filter
    034 Billet diverter valves
    SSAC 3" catless downpipes- Swaintech Ceramic coated
    OEM AUDI exhaust manifolds- Swaintech Ceramic coated
    Full 3” exhaust to a Borla dual muffler setup. (nice and quiet for daily, Angry under WOT)
    OEM LUK RS4 Stage 3+ Clutch with 034 Feramic Stage 3+ Disc
    034 Motorsports Lightweight STEEL flywheel
    034 Motorsports Billet Throwout Bearing
    034 street line engine mounts
    034 street line transmission mounts
    JHM Solid shifter stabilizer bushing
    Brand new OEM Audi diff mount
    APR snub mount with cage
    034 diff carrier bushings
    Low temp thermo switch
    FULL R8 Red coil FSI Coil conversion, with harness / adapter plates,
    New fuel pressure regulator
    New aux fan controller
    New aux water pump
    Mishimoto throttle body boot
    Every possible sensor was replaced (Both o2’s, n75, n249, MAF, coolant, AC switch)
    Every possible seal or gasket is new (including rear main seal) with ALL AUDI OEM PARTS
    ALL AUDI OEM New timming belt kit Tensioner, roller, belt, gaskets, with water pump and thermostat (Timing done at 257,000)
    Metal Thermostat housing
    New Aux Fan
    New OEM Audi fan clutch
    New BOSCH starter
    New Interstate battery
    New Bosch O2 Sensors
    New OEM Audi Radiator hoses
    New Fuel supply lines
    Vacuum check valves replaced along with lines
    New Audi Spider hose
    T-Bolt clamps used on every pressure hose
    Transmission and Diff fluid replaced with Fuchs Sinto Fluid
    Brand new Driveshaft w/ Lifetime warranty from Scotty at AdvancedAutomation
    Brakes/Wheels/Suspension
    VMR V710 18x8 ET35
    Michelin Pilot Supersport AS3's 235/40/18
    Tires probably have 3000 miles on them
    Brembo 6-Piston 18z front BBK (350mm Stoptech cryo Slotted rotors)
    EBC RED pads
    034 Rear BBK (300mm) rebuilt rear calipers, EBC Yellow Pads
    Super DOT 4 Brake Fluid flushed throughout
    H&R Street Springs
    Bilstien Sport yellow Shocks
    034 big rear sway bar
    034 Rear subframe reinforcement bracket
    034 Front & Rear Spherical Endlinks
    New OCAP front control arms
    New front axles ( RAXLES )
    Brand new OEM Audi Steering Rack
    New rear wheel bearings
    Exterior
    Full 3M Clearbra on bumper and 24" up the hood
    Roof rails PC'd Black
    30% tint all around
    Front fenders rolled
    Fresh front bumper hood paint
    Brand new Valeo OEM Audi wipers
    Brand new Foglights with protective film
    Interior
    Full oCarbon Carbon Fiber interior trim
    New European Center LED Screen
    Black alcantara shift boot
    Audi shifter rebuild kit with all parts replaced
    AWE boost gauge
    Innovate Digital MTX-L AFR Gauge mounted in glovebox
    LED interior lights
    Hardwired for Escort Radars
    Cabin pollen air filter replaced
    All 4 bose speakers replaced with Infinity speakers
    Massive folder of receipts, original flip key fob, service key, title in hand:
    Missing pixles?? LOL not a chance. Replaced with European replacement screen. Like everything in this car, It was replaced, upgraded, repaired or fixed.
    - had the hood resprayed prior to 3M Clearbra (was looking fairly tatty after 200k miles and needed refreshing)
    Comes with an VAG OBDII Code scanner
    I daily this car and take it all over the country (recently just drove out to CA, and out to UT, ) ive gone through this car so completely wouldnt hesitate to drive it anywhere.
    if you care to learn anymore about it, l'm happy to txt or discuss it on the phone or, Email me and we'll get in touch.
    the car is a FULLY sorted and cared for by a long time Audi enthusiast since the days of Coupe Quattro's.
    I am moving overseas, which is why I’m selling. Likely to pick up an RS4 Avant while I’m living abroad, and continue my love affair for Audi
    Engine build:
    Metal thermostat housing, fresh OE Audi timing gear:
    insulated inlets and swaintech true ceramic on the manifolds..
    AVCS and Turbo oil feed lines are firesleeved Braided AN Stainless :
    Wagners:
    example of the carbon in the car:
    On Stock Avus wheels:
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    beautiful avant glws!
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Apr 19 2014
    CO
    Thanks bud, truly a great car.
    Apr 19 2014
    CO
    To the top
    Apr 19 2014
    CO
    showing the car this week.
    Apr 19 2014
    CO
    Stage 3 Avant still for sale!
    Jul 07 2011
    PM me if you're willing to part out that CF trim. beautiful car.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by mister4 View Post
    pm me if you're willing to part out that cf trim. Beautiful car.
    lol 😂
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Only halfway joking, but would trade you my B8.5 S4 straight across. LMAO
    Gorgeous car and lots of detail work. If I was in a position to buy it I wouldn't even hesitate. GLWS, can't imagine it will be sitting around long.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Apr 19 2014
    CO
    Thanks for the kind words fellas. Price drop on the car today: 14,500
    Apr 19 2014
    CO
    Still waiting for the right enthusiast!
    Apr 19 2014
    CO
    Established Member Two Rings mrbillydee's Avatar
    Jun 01 2014
    NC
    Judas Priest that's a beautiful and well sorted car!!
    Apr 19 2014
    CO
    Quote Originally Posted by mrbillydee View Post
    Thanks sir!
    Apr 19 2014
    CO
    All PM's replied to and questions answered.
    cheers
    Apr 19 2014
    CO
    Just updated the post.
    also, price bump. 14,000.
    thanks
    Apr 19 2014
    CO
    PM's and text's replied.
    thx
    Apr 19 2014
    CO
    13,500 insane car for the money.
