Results 1 to 4 of 4
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2010 Audi A5 2.0T - misfire, leak - smoke test - 5646 - Leak in Air Intake P2279
    2010 Audi A4 2.0T quattro automatic (not sure what the engine code is for that car).
    Car is idling terrible, tons of misfires.
    Also oil leak rear of engine/transmission (bell housing)
    Erased code, and 5646 P2279 comes back quickly.
    Spark plugs black and build up (not worn much; not sure how hold).
    Installed new plugs, no change.
    Visually inspected hoses, nothing obvious.
    Pancake small vent hole on PCV not showing bad behavior (had newer cars that were blowing/sucking out of that hose, indicating ripped bladder inside).
    Oil cap come off normal with engine running (had cases where bad PCV created tremendous amount of suction, impossible to remove oil cap)
    Rented 'smoker'. Removed air intake box and MAF, and smoked car through large intake hose.
    Found smoke blowing out of PCV housing
    Found smoke (some) coming out of top of timing belt cover front of engine
    Found TONS of smoke coming out of bell housing bottom of engine
    New PCV coming today.
    Never had smoke coming out of the bell housing on any of the cars (1.8T, 2.7T). Is that normal for the 2.0T that smoke (massive) gets from intake hose right into bell housing?
    If not, what might allow that to happen? Bad check valve somewhere?
    I plant to swap in another set of ignition coils I have on hand, but the misfires at idle do NOT seem to be ignition related, rather air leak related (runs better at higher rpm).
    Other suggestions for troubleshooting bad misfires at idle?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Jun 26 2009
    Bremerton WA
    Likely your your rear main seal has failed. It is allowing air into the engine and thru the PCV into your intake to where it reads a lean condition. Also why you have smoke and oil leak there.
    VMR 710's, APR software, Eurocode HFC
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    Requires drop of transmission to correct the seal which is likely a cheap part itself. Quoted 11hr job
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by van462 View Post
    Figured. Oil leak = air leak.
    Replace rear main seal, issues resolved.
    05 Golf TDI
