Results 1 to 3 of 3
Thread: Low psi
    Jan 04 2016
    decatur, texas
    Low psi
    What's the normal psi on a a4 because mine only reaches 10 psi
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Should spike at 13-15 then hold at 10psi
    Do you have access to vag-com?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    My car spikes at 10 also. If you search around you'll find lots of different #, but 10ish psi seems to be the most common quote for our cars in stock form.
