Originally Posted by
drwest
I am in the same boat. My engine is out, just put fresh heads on it, have the JHM kit, and is partially together.
Rather than just winging it, for piece of mind I would rather find someone experienced time the cams. Willing to pony up some good bucks for very little work.
Located just outside of Boulder.
Timing is actually very easy if you have the tools and instructions. It was the thing I was most afraid of and it ended up being easier then removing my control arms (which turned out to be the shittiest part of my whole project). You just have to tighten your bolts correctly (absolutely critical)... You do have the timing tools, right? They are the only thing that matters in order to set timing. You need the Cam Tool, the two horizontal bars, two shims and the crank pin. With these, you just follow the instructions in order, and the timing basically sets itself.
It also helps to know what the three seashells are for... heh.
