Located in Peachtree Corners, GA
ALL PRICES ARE NOT INCLUDING SHIPPING.
RNS-e Unit with nav antenna and iPod hookup with cable, and conversion wiring for the stock radio. comes with North America 2013 map Dvd, no flaws whatsoever - 775$
034 coilpack wiring harness replacement( about 10k miles on it, good condition) - 120$
Ecs 2.0t coil adapter plate - sold
Oem water pump (about 10k miles on it) - sold
Thermostat assembly (about 10k miles on it) - sold
Euro Light Switch no Auto Light Option – 90$
B6 S4 Gauge Cluster (everything works except the trip odometer, it says def for some reason ever since I changed a wheel speed sensor. Time/date and all gauges/screen work perfectly) – 250$
Podi Steering Column Boost Gauge With Column Mount – SOLD
JHM Delrin Shift Knob 5-speed – SOLD
JHM Short Throw Shifter – SOLD
Reinforced glovebox and hinge (common issue on the B6) – 75$
HKS Turbo Timer – SOLD
Armrest Lid non oem black leather – SOLD
Hallman Manual Boost Controller – SOLD
Smoked Side Markers – SOLD
Depo Headlights with 8000k HID bulbs – SOLD
UltraSport Front Bumper Amulet red. It is not an Oem usp bumper. It is a stock a4 upper and an oem usp lower – sold
Q5 Rear Wiper Arm – SOLD
Aero Front Wiper Arms – SOLD
Votex Rear Hatch Lip Spoiler – SOLD
B5 S4 Front Brake pads, Calipers and Rotors – sold
ECS Stainless Steel Brake Lines for the rear (Brand New) – SOLD
RA4 Clutch Conversion Stage 2 (uses b7 rs4 pressure plate and clutch with a lightweight flywheel) about 10k miles on it – SOLD
Head is SOLD
Built Stroker Block- sold
OEM Audi 2.0L Crankshaft
JE Forged Pistons 9:1 Compression ratio
034 Motorsports Coated Main Bearings
034 Coated Thrust Washers
034 Coated Rod Bearings
Scat Forged Rods 144/20
New OEM Oil Pump
New OEM Oil Pump Chain
Magnetic Drain Plug
Stock 5-speed manual trans (no grinding or rough shifts) – 600$
Mishimoto Catch Can Brand new never used - SOLD
Fluidampr Crank Pulley almost new – SOLD
Bosch O2 Sensor about 5k miles on it – 50$
HKS SSQV Blow Off Valve used – SOLD
Forge 004 BOV with some wear on the outside aluminum, works perfectly - 50$
Garret GT3076R Turbo with Billet Compressor Wheel and TurboGuard Screen (will come with 1.06ar exhaust side and a .63ar exhaust side, both are T3 and have a 3inch V-band output) also the compressor housing will have all of the existing black paint removed prior to shipping or pick up – sold
SPA Turbo Exhaust Manifold T3 and Custom 3 inch V-band Downpipe made for the exhaust manifold – sold
Tial 38mm External Wastegate comes with all springs and original shipping box – 150$
SEM Motorsports Intake Manifold Powdercoat Black, small port, 80mm Throttle body. Will include adapter plate for stock throttle body – sold
SEM Motorsports black powder coated Billet fuel rail brand new never used – 95$
Bosch EV14 1000cc Injectors – 200$
Fatty Siemens 830cc injectors old style brand new never used – SOLD
Bosch 040 Fuel Pump with 034 Billet Fuel Pump Mount (in tank pump) – sold
Apikol Snub Mount used – sold
Evolution Racewerks Front Mount Intercooler with piping perfect for an SPA exhaust manifold setup – sold
Ac condenser and pressure sensor - SOLD
Engine speed sensor - SOLD
A lot of stock parts are still available like the sabre black trim, front door cards, front doors (speaker wiring setup for aftermarket door speakers), passenger seat/ rear seats, etc. let me know what you need and I will come up with a price.
Known bad parts that I will not be selling -
Motor mounts
Trans mount
Headliner
A pillar, b pillar, c pillar trim
Sun visors
Sunroof control/overhead lights
All of the engine wiring harness
Thank you for your time and I will try to respond quickly.
So I decided to just message through texting. The app on my phone doesn't show the entire conversation so who wants what gets confusing. So please text all questions to 404-831-0087 thanks guys
