Results 1 to 12 of 12
    Mar 03 2010
    Pitsburgh, PA
    19" Michelin Pilot Super Sport baseline psi?
    About to swap over to the summer setup this week. First time running the super sports. Anyone found a pressure they are happy with to start me out. Every tire is a little different.
    Thanks...
    Feb 02 2014
    Focus RS, Audi S4 & S5
    Knoxville, TN
    36 psi frt, 33 psi rear
    Veteran Member Three Rings Luna's S4's Avatar
    May 22 2013
    Cannondale, two Orbeas & a Trek
    Northern Cal
    36/36. The number of responses to your post will equal the number of different opinions.
    2011 S4 DSG Prestige w/ Revo! Bilstein B16 PSS10! H&R RSB! AP Racing BBK! Michelin PSS!
    Senior Member Two Rings acsgp's Avatar
    Jul 18 2014
    Singapore
    I run 39 psi cold, front and back on the PSS on the 19" rim.
    2010 S4 Avant, Forged bimotos, Brembos, Revo GB tune
    Apr 05 2012
    Earth
    Jul 18 2014
    Singapore
    I used to do 39/36 front/rear for my A6 as it was FWD, and is found that it helped with lessening understeer. But in the S4, I found it didn't make much diff as there was much less understeer to begin with, so ended up with the 39/39. Perhaps it's the sport diff contributing to the lack of understeer.
    Stage 2 Banner Advertiser Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    For Autocross I use 33/30 for extra contact patch and even lower cold on the track, wouldn't recommend it for the road though. Generally your fronts should be in the neighborhood of 3-5 psi higher to account for the extra weight up front.
    Sent from my VS986 using Tapatalk
    AKA: jbullin2
    May 06 2014
    Las Vegas, NV
    I use 39 front 33 rear.... Per manual
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by the4siswickid View Post
    My door jam says 41/41
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Aug 28 2014
    Quote Originally Posted by Works2shoot View Post
    That is for a full load of people/cargo/fuel. Your manual will have different numbers as stated above.
    2014 S4 - Moonlight Blue
    Apr 20 2015
    ND
    For a "full load condition" (max gross weight) vehicle, that would be correct. Manual (for 2012 S4) says 36 front / 33 rear for "normal" load conditions (up to 3 occupants) for high performance 255/35 R19 96Y XL tires.
    39 / 35 for normal load 18" tires if curious.
    Mar 17 2008
    I used 39 front and 36 rear on 245/35/19
