Results 1 to 14 of 14
Thread: Wipers Hitting
    Feb 29 2016
    Bellevue, Ia
    Wipers Hitting
    Bought a 2008 S4 convertible and when the wipers come on sometimes they hit and snap on the windshield any suggestions on could be causing this or how to fix it?
    Nov 13 2015
    East London
    When you say hit and snap do you mean they jump/skid on the windshield whilst wiping?
    Feb 29 2016
    Bellevue, Ia
    It's more when the drivers side comes up it gets a little stuck under the passenger and then pops when it bends to far. It's only sometimes it does it didn't know if it could be a bent arm a misaligned arm? To long of a wiper?
    Nov 30 2010
    San Diego
    Not doubting you... But are you sure you have them on the right side? If you have the old ones I'd also compare the size to them.
    Feb 29 2016
    Bellevue, Ia
    I haven't changed them sorry we just bought the car about a month ago didn't notice it till we got home 3.5 hours away!
    Nov 30 2010
    San Diego
    Hmm... You should have 22" blade on the left and 23" on the right. Time to get your measuring tape out.
    Feb 29 2016
    Bellevue, Ia
    I have 23 on drivers side and 22 on passenger
    Feb 29 2016
    Bellevue, Ia
    Wipers Hitting
    I switched them and will see I tried it seemed to be better. Seems like we might need new words too does everyone go with the 22/23 combo
    Nov 30 2010
    San Diego
    Right on, Good Luck.
    Active Member Two Rings remuspwr's Avatar
    Sep 21 2010
    RX 330
    Is it an OEM windshield? The previous owner on mine had it replaced with a non oem one and my skips and squeals all over the place.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Both 22" works very well. I remember trying to figure this out a couple years ago. But I don't know if the vert windshield is the same.
    Feb 29 2016
    Bellevue, Ia
    Thanks anyone know why the home link would sparratically work
    Feb 29 2016
    Bellevue, Ia
    Wipers Hitting
    Thanks guys I really appreciate the input and help new here so will have a bunch of questions!!!
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    Maybe the PO or mechanic removed the wiper arms off the motor spline and didn't install correctly. You may just need to loosen and adjust the wiper arm on the motor spline.
    Sent from my SM-G920F using Tapatalk
