Results 1 to 40 of 42
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Question Crash bar coating or sleeve options when installing RS4 Grill
    What are you guys doing to coat your crash bar when mounting the RS4 grill?
    Mine is sanded down and I layered some bed liner thinking that would be the end all fix, but I swear it's getting sandblasted down to metal again! I'm going to wait to see if it's just that I perhaps went on too thing but I'm pretty confident I had good coverage.
    IIRC someone here took a round piece of tubing or hose and simply cut it to fit/wrap around the bar and then repositioned the temp sensor. Can't find it but I'm really interested in something like that.
    I'm at my wits end with this damn thing.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Mar 17 2008
    Would the OEM piece from RS5 fit ?
    I have an "RS4" grill waiting to be installed but i just dont like the look of painted crash bar behind the grill. I also dont like the idea of putting fine mesh behind the grill as it will be a nightmare to clean especially during the "bug" season.
    Are there any alternatives to this besides painting ?
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I just covered mine in a thick layer of plastidip never any issues.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    My solution was to cover the crashbar with paint then went with a sheet of black HPDE from Menards. All in it was about ~$20 and looks much better than paint/plastidip since it covers the contours in the crashbar that paint/plastidip do not. Screws in the corners behind the bumper so they are invisible and also used some metal to plastic epoxy on the back in the middle so it sits flush with the crashbar and doesn't bow out. Very happy with the results.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by jl87 View Post
    I'm liking this idea.
    Any other pics of it being installed or anything? Just curious.
    I'm hoping it was just that the bar might have either not fully dried or was sprayed thin in some areas. I just went out and touched up a few bits now and I suppose only time will tell. I do like what you've done.
    Oct 20 2008
    Denver
    Quote Originally Posted by pdqgp View Post
    i used maybe 3 coats of flat black Bed Liner spray. works wonders. not sure why yours started to chip, i haven't had that problem at all.
    Jul 25 2010
    WI/IL
    No install pics unfortunately. Couple of crappy garage pics that shows the HPDE a little better. The sheet was ~$16 and plenty left if it ever needs replaced.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by AudiTFSI3o3 View Post
    I'm going to wait until morning and check it out again. Mine has 3 coats that were dried between applications. The bar was sanded down and roughed up good too. I'm hoping what I saw was just thin spots or the fact that it wasn't but a couple hours before I had to drive it.
    Nov 30 2010
    San Diego
    I painted mine with a flate black cage and chassis paint. I did three layers and after about a year, it's holding up well and looks great. Prior to this I wrapped it, but it didn't look right when dirty.
    Mar 07 2015
    Ottawa, Ontario
    That RS grill looks really good, but I'd be afraid of a rock creeping in and taking out the rad.
    I always put window screen in front of the rad and it's amazing how it preserves it.
    Oct 14 2012
    Empty...for now...
    SE PA
    That is by far the best non-OEM solution I've seen. Thank you for the details on materials and installation method.
    SOLD 2015 Daytona Gray S4
    May 17 2016
    Newyork
    Looks great . How thick was the HPDE you used and is there a void in between the crash bar and the grille itself ?
    Jul 25 2010
    WI/IL
    Probably 1/4". Yes, there is a void between the crash bar and grille because I took out the foam.
    Established Member Two Rings o1brit's Avatar
    Jul 16 2015
    2004 Mini Cooper S - MC-40
    Grand Rapids, MI
    So I'm pretty sure I've seen you're setup posted in another thread, but where did you get your fog light grill setup from? I swear I saw an ECS setup available at one point but haven't been able to find it since. Probably me = weak-sauce web search abilities.
    2012 S4 - Ibis White, Prestige / Titanium, 6MT
    -APR Stage I, Bilstein/H-Sport Suspension, Roc Euro Intake, RS4 Mesh Grille, Hoen Endurance Fogs, P3 MultiGage, BFI Magma shift knob, Ziza LED light kit
    Jul 25 2010
    WI/IL
    They are just the OEM black optics fog grilles.
    Jun 05 2007
    Nashville, TN
    I painted mine with bed-liner, and it looked good for a while. It's been about 3-4 months now though, and yesterday I noticed big pieces of the paint flaking off, presumably from rocks/sand hitting it.
    Ugh, I'll have to take the bumper off to either re-paint it, or come up with a better solution. Has anybody had paint hold up for an extended amount of time? I'd rather paint it, but may have to take a different approach.
    Rob
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by rtmeikle View Post
    Rob
    I think the method posted above is the best bet. The black colored HDPE sheet is black material all the way through, not painted or coated, and therefore should hold up better than the crash bar with a coating on it.
    Jul 11 2016
    2001 BMW R1200C, 2001 SeaPro w/115 OP
    Englewood FL
    Rob
    Yep, I had mine "professionally" painted when I had the grill put on. A year later and it looked like the stars at night (chips EVERYWHERE). So when I did my pulley I brought the whole crash bar to the little paint place next door to my mechanic. He took a look and said "Oh, it's aluminium, it needs a primer before paint will stick to it well, they obviously painted it without that and that's why it's chipping so bad". I had them paint it satin black, cost me $80, no chips since then. It's only been maybe a month, but I think it's gonna be fine. No chips so far.
    '15 S4 | Sepang | Alu Kreuz | CR-15 | 034 DP ECU/TCU | XLR8 196.5mm | HPFP | Merc HX | 034 rear sway | 034 Full inserts | Dinan Coilovers | ECS Kohlefaser Luft-Technik |
    Oct 30 2012
    Oxford, MS
    I used a rattle can of plasti-dip type material that I picked up from a big box home improvement store. It has a more satin appearance. I didn't use any primer. It has held up well. I touched it up a bit the last time I had the bumper off but I'm at 140,000 miles and have been pleased with the results (and was surprised the rattle can still worked since it had been years from the original application).
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Mine's held up really well with rustoleum high performance emamel spray paint, probably did like 4 coats
    Sent from my SM-G965U using Audizine mobile app
    Senior Member Three Rings Jk79's Avatar
    Sep 20 2018
    Chicago
    I used rustoleum outdoor flat black paint 2 coats. But I also put black window screen behind the grille. I wanted to keep full airflow and stop leaves etc from getting through. No chips or fading. Holding up great.
    2018 RS5
    2014 S4 - EPL Stage 2+ (SOLD)
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Plastidip with a bunch of layers, held up great because it has a lot of flex. No chips, I also did the mesh behind my RS grille.
    2012 S4 (sold)
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by 4RCFED View Post
    .... I also did the mesh behind my RS grille.
    This^. Seems to have made a big difference so far, and I also sanded the crash bar prior to spraying bed liner on.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Quote Originally Posted by ModItNow View Post
    I might try your method. LineX didn’t last as long as expected.
    Junior Member Two Rings
    Oct 15 2016
    2-2004 Dodge diesels, dually with everything, S3 2016, A4 2013 sold, 2002 A4 full APR sold.
    Alberta
    I installed black sound deadening matt for mine. Looks good and absolutely no chipping at all. Be careful in installing it and work your way up or down as to follow the groove in the middle of it.
    Established Member Two Rings dean.mohr's Avatar
    May 11 2015
    '01 F150
    Toledo, Ohio
    Did black plasti-dip, I think 5 total coats over the course of a day. Been driving with it in salt-ridden Ohio for over a year with 0 issues. I suppose if you look close you might notice some chips, but nothing down to metal.
    2012 S4 Prestige // Ice Silver Metallic w/Lunar Silver Interior // 6MT // Titanium Package // Chipwerke Pro // CTS Turbo Intake // AWE Track Exhaust (105k)
    2001 Ford F-150...with 265k and counting!
    I'll Always Remember You: 2013 Ford Fusion Titanium
    Nov 27 2017
    Los Angeles, CA
    Quote Originally Posted by Audiacious10 View Post
    Be careful! It can come loose and cause significant damage in the engine bay if a piece is caught by fans, belts, etc.
    Established Member Two Rings rgpwr's Avatar
    Feb 19 2017
    Ft. Lauderdale, FL
    Rust-Oleum LeakSeal. Goes on super thick, is flexible, and stands up awesome. 10k miles now and not a single chip. Way better than plastidip (did that first).
    Jun 05 2007
    Nashville, TN
    Mine (sprayed with bed liner from a rattle can) is chipping pretty badly. I'm thinking of taking the bumper off, re-painting it with bed liner or flat black, and then covering it with 3M clear bra- like this stuff:
    Amazon link
    Any advice? Has anyone does something similar? I don't want to have to remove my bumper again for a third time, so I want to get this right.
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    A few coats of black rustoleum and a few coats of plastidip over the top. Best of both worlds. I went rustoleum only the first time, rocks and debris went down to the metal. No issues after putting dip on top.
    Senior Member Two Rings estorilblue8.5's Avatar
    May 10 2017
    Rye, NY
    Black plasti dip, maybe 5 coats and it looks great. No need for anything else.
    Jan 29 2019
    Markham
    Gonna be painting mine with trunk liner when it gets warmer.
    Anyone know if the crash bar can be easily removed?
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by kaii View Post
    After the bumper is off it’s like 4 or 8 bolts. Super easy.
    Feb 12 2017
    Redmond, WA
    Bought a sheet of HDPE and used a heat gun to form it around the crash bar then zip ties to hold it in place. It's not perfect but with the bumper on you can't tell it wasn't factory.
    Sent from my SM-G955U using Audizine mobile app
    Feb 10 2008
    Ferrari 430 Scuderia, NA1 NSX Comptech S/C, ‘73 Porsche RSR, Rivian R1S, Cadillac CT5-V BW man
    Huntington Beach, CA
    Where is the best place to buy a RS4 grill now?
    Established Member Two Rings SEEY4's Avatar
    May 13 2019
    ATL
    Quote Originally Posted by SCIronMike View Post
    eBay..
    I went with Plastidip. Easy to do, and the foam insert covers up most of it anyway. Do most of you guys remove that as well? I wasn't sure so I put it back on..
    Sent from my Pixel 2 XL using Audizine mobile app
    19 Chevy ZR2
    Past: B8.5 S4 | MkVII Golf R | MkVI GTI | MkV GTI | MkIV .:R32 | MkII 16v GTI | 76 Super Beetle Vert
    Jan 07 2019
    2021 M3 Competition | 2017 Q7
    I used rubberized undercoating. It doesn't have a smooth finish, but it's very thick and very durable. You cannot notice anything when looking through the grille so mission accomplished.
    2021 ///M3 Competition
    Feb 12 2017
    Redmond, WA
    I removed the foam, looks better.
    With the HDPE guaranteed I'll never have to repaint it and it took less time than 5 coats of plastic dip which is what my alternate option would have been.
    Feb 10 2008
    Quote Originally Posted by SEEY4 View Post
    eBay..
    Is there a particular vendor on Ebay?
    Feb 12 2017
    Redmond, WA
    stonecarbon seems to be the consensus on the best currently. I have it on my b8.5 and it's actually very good quality. My only complaint is the mesh between the rings looks a little strange but otherwise it's great quality.
