Results 1 to 9 of 9
    Junior Member One Ring Macreed_65's Avatar
    Jul 07 2014
    Roseville, Ca
    Lightbulb Bosch 404 vs. Stock Fuel pump questions....
    Ok so it looks like my fuel pump is failing.. So taking it in for fuel pump replacement and fuel filter (while their there).. From what I've read, stock pump has a max flow rate of 50 gph and my choice for replacement/upgrade, the Bosch 040 has a flow rate of 62 gph which can support up to 521 hp...
    I was wondering those that have upgraded their fuel pumps and would their be any noticeable difference with my current set up??
    Obviously, it'll be ready for stg3 when I decide to pull that trigger..
    Thoughts, ideas, input from any of you technical guys in the group would be appreciated...
    2005 allroad, daz stg3+ tiptronic tune, stg2 stukler tune, 3" dp's, forge dv's, 034 ceramic coated bipipes,
    Sep 11 2009
    NE
    040 is not a good choice anymore. Go with dw301 or similar pump, cheap, reliable, easier to install and flows far more than stage3 will ever need.
    Dec 16 2014
    Irvine, CA
    I agree bosch pumps are old and loud. There are much better choices out there. Aeromotive , AEM or Deatschwerks. Especially if you want to run E85. Walbro 450 E85 specific pump is great too, not sure if it would fit, since it is a bit bigger.
    Sep 11 2009
    NE
    Walbro 450 is not a good choice for stock unmodified supply ssytem + rails since it will heavily peg the FPR leading to low load/idle fule pressure problems. It supplies too much fuel for low pressure side of FPR to return it to tank without pressure spike on low pressure side leading to supply side floor pressure of about 4 bars. You also need to upgrade wiring to Wlbro 400/450 since it takes some majors amp and you will burn your wires out with time.
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    Quote Originally Posted by julex View Post
    the 400 and the 450 are different pumps no?
    never heard of any wiring issues with the 400
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Anything extra needed for the dw300 or dw301?
    Sent from my SGH-M919 using Tapatalk
    Sep 11 2009
    NE
    Quote Originally Posted by Racin2redline View Post
    400, 415, 450 are the same pump revised with time, I think it might even have the same part#, forget now.
    http://www.audizine.com/forum/showth...=1#post9080791
    Aug 19 2012
    Long island
    I have mine wired in exactly like stock...no issues so far but I'm going to check out the wiring when it gets warmer
    now that you mention it, your right. the 485 pump has sealed wiring connections with the plug coming off of it to be ethanol safe
    IG: d3bel1o
    Senior Member Two Rings frankwizzle's Avatar
    Oct 08 2008
    Derby City
    Quote Originally Posted by Royal769sr View Post
    No, just maybe some o-rings to make it fit snug in the basket. Otherwise it wires straight up.
    Sent from my Nexus 5 using Tapatalk
