Results 1 to 7 of 7
    Established Member Two Rings Haole_Audi's Avatar
    Nov 27 2013
    Honolulu, HI
    Replacing the N205 but t20 just stripped bolt
    Trying to replace my N205 and read that I need the t20 bit size. Got one bolt out, however the other just stripped after 2 tries. Any solutions?
    Nov 15 2011
    Montreal | I sell in USD
    Sometimes its a triple square if I'm not mistaking.
    *****I sell in USD*****
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    use any grinder you can fit back there and make it a flat head, try a bolt extractor, vise grips, weld a bolt to the head of the stripped one. lots of ways to get it out, you just have to be creative and pick the best one for your situation.
    Nov 27 2013
    Honolulu, HI
    Shit sucks when it's suppose to be a 5 minute process and turns into needing 10 tools and 2 hours of work....
    The triple square screw holds a bracket next to the N205. I don't need to take that off.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by Haole_Audi View Post
    My triple square got stripped when I was doing my n205 . I drilled the screw out a bit, and took a torx 30 screwdriver and used a hammer to beat the screwdriver into the hole i just drilled. Then I and it came right out. Im sure something similar would work for you, just you'll probably want to get a different screw for next time
    2007 Porsche Cayman | 5MT
    Nov 27 2013
    Honolulu, HI
    Yea I got it. Took a flat head and just hammered it to make the grooves, came right out after that. All done plus oil change.
    Nov 15 2011
    You're right, my bad. I just remembered using an odd triple square when I removed mine
