Originally Posted by
joediesel
Is it possible to balance a tire on a bent wheel? I have a similar vibration, only from 50 ish to 60 ish mph, thought the tire was out of balance, had them balanced and same issue. Replaced the hubcentric rings and still the issue persists. Is it possible my wheel is bent yet the tires are still balanced? Wheels are coming off next week anyway for the summers...
The shop that balanced the wheel should have easily seen if the wheel was bent (either visually or intuitively) when they were working on it... did they tell you it was bent?
Depending on how much of a bend it can only be corrected it so much... roadforce balancing is your best bet... but - you may consider just replacing that one wheel with a new one or getting the wheel fixed if the vibration continues..
Putting your summer wheels on will be a good test to make sure it's in fact a bent wheel vs something else causing vibration (warped caliper... etc). If you still have the same vibration after you chance your wheels then it's most likely something else (unless both sets of wheels have the same bend/s in the same wheel/s (not likely).
