Originally Posted by
GrapeBandit
There has been a few threads lately in regardes to brake upgrades, so I figure I will try to compile a list of both front and rear upgrades so we have everything in one place for ease of future reference.
This list is incomplete as of now, I DO NOT know what is required to run ALL of these setups on both pre-facelift and facelift cars. With the help of the rest of you guys, I hope to complete this list. If anyone has anything to add(part #'s, tips/tricks, other notable setups, etc.), post it and I will edit it into the 1st and 2nd posts.
FRONT-
D2 A8 BBK:
B5 A4 Calipers
D2 A8 312mm x 25mm rotors 8E0 615 301 R
TT Carriers 1J0 615 125 A
Requires new brake lines?N
Boxster 986 BBK:
Boxster 986 Caliper Rt 986 351 422 03
Boxster 986 Caliper Lt 986 351 421 03
TT Carriers 1J0 615 125 A or Apikol/PureMS brackets
Requires new brake lines?Y
Boxster S BBK:
Boxster S Caliper Rt 996 351 426 11
Boxster S Caliper Lt 996 351 425 11
or
B5 S4 321mm x 30mm rotors 8E0 615 301 AD
Porsche 993TT BBK:
993TT Caliper Rt 993 351 426 10
993TT Caliper Lt 993 351 425 10
or
Apikol 323mm x 32mm 2-piece floating rotors
or
Mercedes Benz C230 330mm x 28mm rotors 203 421 13 12 *(machine center hub a few mm, and drill lug bolt holes to 14mm) (with corresponding brackets)
or
Volvo V70R/S60R 306 452 22 330mm x 32mm *(open lug holes with a 3/4" bit, and minimal grinding to uprights) (with corresponding brackets)
Apikol/2Bennett brackets
•Notes• A.K.A. Porsche Brembo Big Red/Black found on both 993s and 928GTSs
If you choose to swap to B5 S4 uprights instead of running the brackets. . .
17z 330mm BBK:
17z Caliper Rt Porsche 955 351 422 33/Touareg 7L6 615 124 H/Audi Q7 7L6 615 149
17z Caliper Lt Porsche 955 351 421 32/Touareg 7L6 615 123 T/Audi Q7 7L6 615 150
Mercedes Benz C230 330mm x 28mm rotors 203 421 13 12 *(machine center hub a few mm, drill lug bolt holes to 14mm, and need 2mm Apikol shim or steel washers)
or
Apikol 2-piece 330x32mm rotors
Apikol brackets
Confirmed fitment-Centric (Stoptech branded) 950.33005 brake lines
17z 345mm BBK:
17z Caliper Rt???
17z Caliper Lt???
rotors???
Apikol brackets
18z BBK:
18z Caliper Rt 7L6 615 150
18z Caliper Lt 7L6 615 149
17z brake pads
Mercedes Benz C32 AMG 345mm x 30mm rotors 203 421 09 12
Apikol brackets
B6/B7/B8 345mm BBK:
*Requires B5 S4 upright conversion*
B8 S4 Caliper Rt 8K0 615 124 G
B8 S4 Caliper Lt 8K0 615 123 G
B6/B7 S4 345mm x 30mm rotors 8E0 615 301 T
B8 S4 Carrier Rt 8T0 615 126
B8 S4 Carrier Lt 8T0 615 125
Requires new brake lines?Y/N?
Just adding my recent BBK which is similar to, but not the same as anything on this list.
D2 S8 4 pot Brembos
*I did this with a B6 upright conversion but I believe it could be done without*
D2 S8 Caliper Lt 4D0615107D
D2 S8 Caliper Rt 4D0615108D
D2 S8 Pads (apparently some D2 S8s came with HP2s, careful to order Brembo pads)
Apikol 993TT brackets (I used B6 to 993tt brackets, may be possible to use B5 A4 to 993tt brackets as well)
StopTech 950.33005 (B7 RS4 lines)
The calipers are similar to 993TT calipers with some slight variations (IIRC they share a part number). As far as mounting goes, they are the same. However, the D2 S8 version can support a larger 345x30mm B6/7 rotor.
