Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 156
  1. #41
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by melomandn View Post
    Out of curiosity, why don't people run B6/B7 S4 front brakes on B5 S4 spindles? Demonmk2 touched on it, although mentioned B8 calipers. Any reason the B6/B7 calipers wont work? Seems like a cheap alternative to get a big (345mm) setup up front.
    Because if I am going through that much work, I want something pretty. And 17z/18z isn't that much more.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
  2. #42
    Dec 10 2013
    Borden, Ontario, Canada
    Great thread, wish this was put together 5 years ago.
    Because its a poor single piston caliper with a larger rotor. Sure it's far superior to the stock brakes, but what's the point?
    Redline words it well. If you're going to go that big, may as well get something pretty to look at
    Quote Originally Posted by redline380 View Post
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
  3. #43
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by RS4Avant2be View Post
    Rear - inexpensive option
    A6 upgrade (255 mm x 10 mm)
    A6 2002 3.0L & 2.7TL Q (C5) rotors 4B0 615 601 B
    A4 B6 (2002) 3.0L Carriers 8E0 615 425 G
    Stock A4 B5 Calipers & Pads & brake lines
    Works well with A8 front upgrade
    Quote Originally Posted by tymatk View Post
    In need for rear brake, already got A8 front, this helps alot, thanks. Would these do ....
    Audi / A4 / 2001 / Sedan / Red / Automatic WAUZZZ8E12A10XXXX ALT059265
    Audi / A4 / 2003 / Sedan / Black / Automatic WAUZZZ8E53A38XXXX BFB033291
    Audi / A6 / 1995 / Wagon / Black / Automatic WAUZZZ4AZSN09XXXX ABC132614
    Just a list from my local wrecker.
    Quote Originally Posted by GrapeBandit View Post
    the 2001 is good for the rear calipers.
    the 2003 should have the carriers if its a 3.0.
    the 1995 a6 has nothing for this brake upgrade.
    You meant Rotors?
    nope, i meant calipers. isnt the above what you are trying to accomplish? the c5 a6 255mm conversion? you cant use b5 a4 rotors for the a6 upgrade, you need the a6 255mm rotors
    Quote Originally Posted by demonmk2 View Post
    on the 986 bbk (312x25) you can use the usrt mk1 TT brackets/adapters too. I bring it up because they're about 100 bucks cheaper.
    also, you can swap b8 s4 brakes/brackets with ( 345mm b7/b6rotor) on a b5 S4
    Quote Originally Posted by Bordom View Post
    so should i add it to the list, or not?
    lmk
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
  4. #44
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    The thing is, it is almost impossible to have an absolutely comprehensive list of brake upgrades. Literally any caliper ever produced *could* be installed on your car with the proper modifications. Nobody does the b6/7 s4 front upgrade because it doesnt have much to offer that similar kits do.
    The main thing that opens us up to upgrades is B5 S4 uprights. After that, you can go up to B8's, TTRS, shit even R8 brakes may be an option (Hint hint- VW clearanced 2015 R8 v10 calipers down to $700 per side from $2200 per side. Search "R8" http://www.vwparts.com/parts-outlet-center/index.php If you want them even cheaper, put the PN's into GAP's wesbite and they can be had for $610/piece. Not sure what you would do for rotors since those calipers use cermaic rotors though!)
    2000 S4- Working?
  5. #45
    Dec 13 2010
    FL
    lol. obviously with enough time and the proper funding, you can make anything fit.
    maybe i worded it wrong, but by no means is it an "absolute" list. its more like a list of OEM parts that are readily available and commonly used to piece together your own BBK without feeling it in your pocket too much
  6. #46
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I know what you meant
    Here's how I see it.
    Minimal effort- Decent set of pads and rotors.
    DD with better power- A8 upgrade
    DD with slightly better- A8 with B5 S4 rears
    That basically keeps cost well below $1000 for all brand new stuff, but a savvy shopper would have around $500 invested in the entire setup.
    If you want something over that, the door is wide open. But as we have discusses, you will be going B5 S4 uprights to fit whatever it is you want. IMO, you might as well skip all the lower stuff and just go 17z/18z depending on what you run for wheels. Upgrades like 986 could be considered, but I don't see much reason considered how cheap the 17z options are. However, 986 upgrade is a little more "bolt on ready" considering brackets are available and you dont have to do grinding/modifying rotors.
    If you want something more than 17z, than screw you go look it up yourself. There is no reason to have that kind of braking on a street car. If it is a race car, talk to your race team.
    2000 S4- Working?
  7. #47
    Established Member Two Rings Blur2u's Avatar
    Oct 01 2004
    San Diego
    GrapeBandit just wanted to add that when i did my 17Z rotors using Mercedes Benz C230 330mm x 28mm rotors. I had to buy a 2mm shim that apikol sells (i guess you can use washers also) that will give the Mercedes rotors the correct offset, that way the rotors are centered in the 17z calipers. Also you will M12X1.5X25mm grade 10.9 brake caliper mounting bolt.
  8. #48
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    This is the answer I expected, as I completely agree. Was purely curious.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
  9. #49
    Apr 01 2011
    B5 on jack stands
    charlotte
    As far as the b8 s4 calipers it's o good option if you want to run different wheels. I've noticed with 17z/18z it limits the wheel choices using those calipers. That's what my buddy ran into. So he went with the b8 s4 upgrade to run a 35et 18x9 mesh wheel
    powered by
    Hot Boi parts
  10. #50
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    True.
    I would like to mention that 17z's clear 17" Celebration wheels though. It is very tight, but they clear.
    2000 S4- Working?
  11. #51
    Senior Member Three Rings ElSabio182's Avatar
    Feb 26 2006
    Boston (formerly Rochester NY)
    True.
    Might be a worthy endeavor for people to shout-out which setups will clear some popular wheel sizes (since that's gotta be the next-most-common question on this topic).
    For self-serving purposes, I'm trying to find out if a 17z 330mm front / B5 S4 256mm rear setup will clear 17-inch B6 sport wheels…(which I believe are 17x7.5", ET45)
    Great thread. Subscribed. Thanks!
    TOTALED: 2001 A4 2.8L QST - RIP, April '07 (carnage pics)
    TOTALED: 2000 A4 2.8L QSM - RIP, Sept. '09 (Totaled...really??)
    TOTALED: 2001 A4 2.8L QSM - RIP, Aug. '13 AGAIN?!
    Current: 2001.5 A4 1.8T QSM - A8 front brakes / KW V2s / front-rear 034 swaybars & endlinks / JHM DTS / Valeo clutch / S4 tie-rods / S4 skirts / Sport Cloth seats
  12. #52
    Dec 13 2010
    FL
    Quote Originally Posted by Blur2u View Post
    thanks. I will note it
    Quote Originally Posted by ElSabio182 View Post
    yes, the next thing I am going to do is try to add a list or wheels, or the size of wheels that these brake kits will clear
  13. #53
    Apr 01 2011
    B5 on jack stands
    charlotte
    also wanted to add that the ( used ) b8 S4 calepers/brackets and b6/b7 s4 rotors ( 345mm) cost about 500 bucks. so its a cheap big brake upgrade.
    on an A4 you would have to use S4 B5 uprights
    powered by
    Hot Boi parts
  14. #54
    Senior Member Three Rings DoesntCare's Avatar
    Feb 28 2016
    SEPA
    Any idea if the carriers from a 3.2L TT work for the basic upgrade in the front?
    1.8t TT's have single piston calipers up front with a 12.3" rotor
    3.2 TT's have dual piston calipers up front with a 13.15" rotor
    I'm not seeing the part number you have listed for the TT carrier as fitting the 3.2L but I figured I'd double check
    P/N I found on ECS for the 3.2L carrier is 8N0615125A
  15. #55
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Comprehensive list of OEM b5 a4 brake upgrades
    What i would like to know is if the carrier from an a6 c5 3.0 with 312mm rotors and g60 single piston ATE calipers will work with b5 a4 front calipers in order to do 288-312mm rotor upgrade?
    Better yet, would the entire g60 caliper/carrier combo work with 312mm rotor on b5 a4 spindle?
    Reason i ask is because i am trying to avoid spending 150 per TT carrier and at the moment, rockauto doesnt have any front TT carriers.
  16. #56
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Quote Originally Posted by a4kamila6 View Post
    What i would like to know is if the carrier from an a6 c5 3.0 with 312mm rotors and g60 single piston ATE calipers will work with b5 a4 front caliper in order to do 288-312mm rotor upgrade?
    This is the same as the B6 A4 3.0 312mm and the B7 A4 "sport" breaks. you will need uprights if you don't have carriers. 98% sure, others will correct me if not.
    SOLD the GOINHAM A4 ---> GT2860 Project
  17. #57
    Dec 10 2013
    If over B5 S4, uprights are required
    IG: 24_et
    Sold:
    RIP:
  18. #58
    Sep 30 2015
    Quote Originally Posted by GOODBYNAAIR View Post
    So to use g60 ATE calipers/carriers with 312mm rotor i need b5 s4 spindle? Or can i re-use b5 a4 spindle? I thought maybe i could get away with just using the caliper/carrier and not having to replace spindle.
    If i need s4 spindle for this then i guess im better off just sourcing those TT carriers and re-using my old b5 a4 calipers with 312mm rotors?
  19. #59
    Dec 10 2013
    It's the same diameter. If you're going to switch the S4 uprights, get a BBK that is going to perform a hundred fold over a single piston
    IG: 24_et
    Sold:
    RIP:
  20. #60
    Sep 30 2015
    Hmmm i was trying to avoid s4 uprights and just get 312mm rotors, leave b5 a4 calipers with TT carriers or get g60 ATE calipers with carriers and also use 312mm disc with b5 a4 upright.
    And you are right if i upgrade to s4 spindle i might aswell go true bbk but the problem is my summer wheels are 17x7.5 et45 a6 stockers i got from someone, test fitted them over hp2's and they didnt clear, so that goes to show they probably wont clear a big caliper, would need at least 5-10mm spacer and i am trying to avoid spacers. Winter wheels are 16x7 et35 a4 stockers, and they will clear a 312mm rotor but i dont know about a true BBK. Trying to keep costs down as low as possible cause this is my daily and i should be wasting money on my 2.7 and not this.
  21. #61
    Dec 10 2013
    The HP2 calipers are 10mm wider than 17z calipers. Which is ridiculous.
    There is a 16" steelie that will fit over the HP2 brakes but I don't recall what it is.
    Find the Mk1 TT carriers and use your A4 calipers. Forget the C5 3.0 brakes.
    IG: 24_et
    Sold:
    RIP:
  22. #62
    Jun 30 2008
    Erie, Pennsylvania
    $300 in carriers! Dude, just dial up a junkyard that has an MKI TT. They'll sell you the calipers for like 30 bucks each. And they come with the carriers...for freezies. You might even get the pads and half a brake line. Literally everyone just gets reman calipers at Autozone these days, so junkyards have to basically give away their used calipers. Get in on that action.
    Absolute worst case, you buy 2 reman TT calipers from RockAuto for $45 each, and eat the $40 core price on them. That's $170 total.
    2001 Aluminum Silver A4 Avant 1.8TQM (winter sled)
    2005 Piano Black VW Phaeton W12, Leaky Air Springs, DTC Addiction.
  23. #63
    Sep 30 2015
    I didnt think of trying junkyard, good point man.
  24. #64
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That's B5 ownership 101
    2000 S4- Working?
  25. #65
    May 17 2014
    Raleigh, NC
    this made my day...
    Im a huge advocate of the 986/boxster set up... I ran it on my MKIV (liked it better than my 18z set up actually) and currently run them on the b5 (with upgraded v8 rear brakes) and have never needed any more.
    Keep in mind, im using Cheap $50 oreilly ceramics (lifetime warranty ftw) and if I ever need more Ill just buy better pads. maybe slot the rotors if you track it every once in a while.
  26. #66
    Apr 01 2011
    B5 on jack stands
    charlotte
    you could look for 986 Baxter calipers to use with the 312mmx25 rotors. and still use the a4 uprights.
    no matter what I recommend upgrading the rears to at least S4 specs.
    powered by
    Hot Boi parts
  27. #67
    Nov 08 2010
    Upstate New York
    For real tho
    - B8 S4, Stage 2+
    - B6 S4, not stock
  28. #68
    Established Member Two Rings grifrowl's Avatar
    Jun 26 2014
    2002 S4, 2001 A4qt, 2003 A4qt
    Utah
    B7 S4 300mm:
    B5 S4 Caliper Rt 8D0 615 424 C
    B5 S4 Caliper Lt 8D0 615 423 C
    B7 S4 300mm x 22mm rotors 8E0 615 601R
    Apikol/034 brackets
    Requires new brake lines?Y
    Confirmed fitment-Centric (Stoptech branded) 950.33005 brake lines
    This can also be done with b6/7 S4 calipers, which are slightly bigger than b5 s4 calipers. Requires 10mm spacers and 10mm longer bolts than stock. Also requires 10mm to 12mm adaptors or b6 brake lines as outers.
    http://www.audizine.com/forum/showth...yard-b5-brakes
  29. #69
    Jun 26 2014
    Utah
    PS we have grabbed a few pairs of 17z calipers through worldpac for very respectable prices.
  30. #70
    Dec 24 2010
    2001 A4 4.2 v8 swap, MR2 Turbo, CBR1000rr
    Columbus, Ohio
    So i am a bit confused
    i have an 01 A4
    I have C5 A6 V8 rear calipers/ brackets and A8 rotors
    The bracket will not fully bolt up to my knuckle, bracket interferes, which bracket do i need?
  31. #71
    Dec 10 2013
    Quote Originally Posted by spinnin_four View Post
    i have an 01 A4
    If you read the second post carefully, it says to use the A8 rotor/carrier with S4 calipers.
    I'm not sure if the C5 V8 calipers are the same as the B5 S4 calipers
    IG: 24_et
    Sold:
    RIP:
  32. #72
    Dec 24 2010
    Columbus, Ohio
    I think i found a way to make the A6 caliper/carrier work with the A8 rotor,
    I ground down the carrier at the point it was interfering with the knuckle
    Then the next dilemma was the carrier offset was wrong causing rotor interference, i picked up some 2mm "shims" to space it out.
    everything bolts up, parking brake, A6 brake hose connected into stock hard line, all is well so we shall see :)
  33. #73
    Senior Member Three Rings 155VERT83's Avatar
    Jun 30 2009
    ‘05 Porsche 997 Carrera, '15 MBZ C300 4Matic
    Alexandria, VA
    "Out of curiosity, why don't people run B6/B7 S4 front brakes on B5 S4 spindles? Demonmk2 touched on it, although mentioned B8 calipers. Any reason the B6/B7 calipers wont work? Seems like a cheap alternative to get a big (345mm) setup up front."
    melomandn I went with the B6/B7 S4 front calipers & B5 S4 spindles option for my 2001 B5 A4 Avant 2.8Q (Tiptragic!). I wanted a low cost, bolt-on, OEM solution that required absolutely no grinding/clearancing. My B6 S4 calipers were $140 shipped (eBay: calipers $120/shipping $20). ECS Tuning: 345mm rotors $139 shipped- bought add'l $61 of stuff for "free shipping with $200 order"). My car is a daily driver (no track action) on horrible, congested Wash. DC/Northern VA roads. I can opt to move to the 17Z/18Z's later. For now I'm OK with the no-so-pretty B6/S4 calipers.
    2021 Tiguan R Line (replaced 2012 A4 S Line)
  34. #74
    Nov 08 2010
    Upstate New York
    Quote Originally Posted by 155VERT83 View Post
    The more I think about it, I take back what I said earlier and believe this is a great route to take.
    Even if you pick up a set from a scrapyard or car-part.com or whatever, 17/18z's will still cost 3 times as much as B6 S4 calipers. And as you said, if you want to upgrade later on, it is nice and easy.
    Additionally, after seeing a few of these swaps in person, of course its not as visually pleasing as a set of Porsche Brembo's but it is still a nice visual upgrade. It fills out the wheel and the caliper looks huge in comparison to stock.
    - B8 S4, Stage 2+
    - B6 S4, not stock
  35. #75
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    I just completed the rear A8 269mm brake upgrade, using B5 S4 rear calipers, C5 A6 V8 rear carriers, and PBR ultimate pads. This, along with my A8/TT front upgrade and SS lines has made a huge difference. Can confirm on spacers, I just used some flat washers I found on my workbench and the carriers mounted right up, no problems.
    BTW, my 17x8 wheels barely clear the rear brakes, the back side of the wheel is about 1/8" from the caliper.
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
  36. #76
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by bikerbob951 View Post
    Funny because I have plenty of clearance on my 300mm rear upgrade with 17" celebration wheels
    2000 S4- Working?
  37. #77
    Veteran Member Three Rings pee quu's Avatar
    Jan 25 2009
    Oceanside, NY
    I put B7 A4 front calipers on my car. It was super cheap, painted them black I am even running them with the S4 caliper spring. Looks good and gets the job done. Gives more room for better wheel fitment compared to a 17z/18z caliper. Granted you need B5 S4 up rights to use these calipers.
    2000 B5 A4 / C5 S6 V8 swap / B5 S4 driveline swap / PVW Nov 2016
  38. #78
    Jul 25 2008
    Cincinnati, OH
    Well the clearance I mentioned is from the back of the wheel face, not from the caliper to the rim.
  39. #79
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    That's an offset issue then.
  40. #80
    Jan 25 2009
    Oceanside, NY
    it depends on the wheel is made, for example ccw you can have an et 35 on a 9.5'' wide wheel with a 3'' lip or u can have an et 35 on a 1'' lip. The way the wheel sits on the car doesn't change. The face just moves in and out depending on the lip size and the et stays the same. The 3'' lip will have a face with a smaller back pad limiting big brake fitment vs the wheel with a 1'' lip will have a large back pad giving plenty of room for big brake fitment
