Results 1 to 11 of 11
    Dec 01 2015
    boise idaho
    Parting out a 2007 RS4 4.2engine (BNS)
    Lost the engine in my 2007 RS4. . Bought a couple to combine and rebuild. I am selling all the left over good parts. I have the following parts.
    2 blocks, both with 1 Bad cylinder each. Candidates for sleeving for boost. One of the blocks could be used for oversized JE pistons without sleeves but is missing the lower block.
    One crank that lost a rod bearing but is easily repairable.
    One complete set of good rods.
    One set of cylinder heads complete with cams, etc.
    Old style valve covers,
    One fuel system with high pressure pumps, lines, injectors.
    Upper and lower oil pan,
    Sensors,
    Timing set with good tensioners, timing covers.
    Dampener,
    Flywheel and good pressure plate.
    Let me know if you would like pictures emailed of any of the components. Thanks, Toby
    Dec 01 2015
    boise idaho
    Possible trades
    Would also be interested in trading for good parts. I need coil overs, JHM shifter, Front seats? Let me know if you need engine parts and have anything to trade.
    Established Member Two Rings wagonlove's Avatar
    May 30 2012
    S-Works%20Road%20Bikes
    Dallas, Texas
    Any chance you have a passenger front S4/RS4 style door blade from those project cars? Preferably black but anything works.
    2005.5 B7 Avant - 6MT, Stage 2 (SOLD)
    2012 B8 Avant - Stage 1
    I love Audis but spend all my money on bikes
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    How much are you looking to get for everything, minus the rods and worst block?
    -Tim
    Established Member Two Rings SweetinsanityTT's Avatar
    Oct 09 2010
    2007 Audi RS4, 2010 Volkswagen Jetta TDI (Sold), 2001 Audi TT Quattro Big Turbo (Sold/RIP)
    Other Side of the Pacific
    You wouldn't happen to have the small aluminum coolant flange that goes between the manifold and PCV Valve. Part # 079133424E or 079133426C. Also sent a PM.
    Dec 01 2015
    boise idaho
    I don't have any parts except from the engines minus intake systems. PM me with anything you need and your email and I'll send pictures.
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    PM'd
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Established Member Two Rings IbisRS4's Avatar
    May 10 2009
    RS4
    Still have the lower oil pan?
    Apr 05 2011
    98 Honda Prelude Type SH
    Fayetteville, NC
    Timing chain guide rails?
    Veteran Member Three Rings shokwav09's Avatar
    Jul 26 2009
    hhr, 2013 rs5
    kansas city, missouri
    Quote Originally Posted by tjtbelmont View Post
    Sensors,
    Dampener,
    60 for the alternator bracket/mount shipped
    I wanna do a burnout at heavens gate in an audi
    Junior Member One Ring Crump3t's Avatar
    Dec 27 2014
    '91 E30 318iC
    UT, USA
    How many miles on the fuel system components?
