Results 1 to 9 of 9
    Feb 01 2016
    1993 Mitsubishi 3000GT VR-4
    Ontario, Canada
    2010 S5 Clutch Pedal Issue
    So I've done some searching around the forums and there seems to be a ton of different thoughts on this problem so I figured I'd try to get some more opinions.
    I'm currently driving my 2010 Audi S5 that has about 60K miles on it. About a month after purchasing the car my clutch pedal has begun to act a bit strange. While I'm driving and I go to switch gears it will intermittently be slow to return to the up position. It always seems to come fully up, and it isn't a super slow return, but it is noticeable. If I bring my foot up slowly with the clutch there is no issue but if I fully depress the clutch pedal and quickly remove my foot from it it will take a little longer to come up.
    Now this isn't a constant issue at all. It seems to actually get better the longer I drive the car, although this may just be a coincidence. I need to do more testing on that front.
    Has anyone else ever run into something like this? It isn't a huge issue as of now, more of an annoyance, but something I'd like to fix if possible.
    2010 Audi S5 | USP Motorsports RS5 Grille | RS5 Style Fog Light Grilles | AWE Tuning Track Exhaust | AWE Tuning S-FLO Carbon Fiber Intake | CR-15 Upper Strut Brace
    1993 Mitsubishi 3000GT VR4 | Lightly Modified
    Oct 14 2015
    Colorado
    Quote Originally Posted by downey13 View Post
    I have the same issue in my 2011 S5 with similar mileage. It started as the weather got colder(3 months ago), and the problem disappears on warm days. I've searched a lot of forum posts on this topic, haven't found a definitive root cause or fix that resolves it. I'm going to see if the problem sorts itself out when the weather changes; if not then I'll have a shop diagnose and fix it ($$$$). If you fix your sticky clutch pedal, please let me know how you do it.
    Senior Member Two Rings jwr9152's Avatar
    Apr 08 2015
    Pensacola, Florida
    I had this issue with mine and it was the self adjusting pressure plate. Had to replace the clutch. Went with an aftermarket non self adjusting pressure plate.
    2011 S5 6 spd 4.2 V8 with APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, Meisterwerk short shifter, 034 transmission mount, Stoptech BBK, carbotech xp12, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace, Advanti Hybris 19X9.5, Michelin Sport Cup 2 275/35/19. USP RS5 grill. 034 Motor Mounts
    Veteran Member Three Rings TTRStud's Avatar
    Jul 12 2013
    Jacksonville, FL
    Audi seems to employ a lot of unreliable technology that we end up getting rid of - for example: self-adjusting pressure plate, hydraulic motor mounts, etc. What a bunch crap only good for marketing purposes. I wish they would just produce something solid and stop with the "truth in engineering" bullsh*t.
    '10 Meteor Gray Metallic S5 Prestige Loaded 6MT - AWE Track - PCed OEM Rotors
    Feb 01 2016
    Ontario, Canada
    Quote Originally Posted by jwr9152 View Post
    This is exactly what I was hoping I wouldn't hear haha
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Quote Originally Posted by TTRStud View Post
    Welcome to German engineering: 'If it's more complicated (and ideally made of a plastic), it must be better'
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Established Member Two Rings Crusader105's Avatar
    Jul 22 2014
    2010 Subaru Forester XT, 2005 G35 Coupe, 2006, 2015 WRX STI Kawasaki 500R, 1986 RX-7
    Elora, ON
    I have an A5 with the M6 trans and experienced this slower return when it's really cold, like -20C. Goes away as soon as the car warms up though.
    While it could be a pending clutch plate issue, it might be a simple as you may need to flush the clutch circuit with new brake fluid? When was the brake system last flushed, they are a common reservoir?
    Do the easy, cheap stuff first!
    I also understand there's some sort of flow restriction device in the slave line that meters the fluid flow. Not sure if it functions on apply or release or both? Maybe it's buggered.
    There was a thread about a month ago about replacing the clutch slave line to eliminate the flow restriction. This seems to provide a better apply/release feel to the clutch at the pedal.
    2010 A5 Prestige in Meteor Grey Pearl/S Line/Tech Pkg/M6/CR-15 Front Strut Brace
    Jul 12 2013
    Jacksonville, FL
    Quote Originally Posted by BoostEasy View Post
    Lol not to be a brand whore, but BMW products seem of higher quality...at least my M cars have been.
    Apr 08 2015
    Pensacola, Florida
    As Crusader said, try the easy stuff first. You can also try the return spring on the pedal itself. I replaced the entire pedal assembly, took out the online restrictor, switched to a ss line, replaced the slave cylinder, but none of it helped. Changing the clutch fixed it. Clutch was in perfect condition, pressure plate was shot.
