Results 1 to 9 of 9
    Feb 06 2016
    Honolulu
    Silicone Key Fob Cover
    If you're clumsy like me, dropping your key fob is a constant source of frustration. The biggest frustration is when the case gets banged up and nicked.
    So I took a chance and ordered two (for both my fobs) silicone cases that are listed on Ebay.
    Cheap (a few $'s)
    I have to say, they fit perfectly, allow the buttons to work, and the bright colors allow me to spot the keys a little easier to these old decrepit eyes of mine! LOL!
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Silicon is awful. Hard to get in and out of pockets and picks up every little particle of dirt that it can.
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by adam044 View Post
    ^+1
    The stuff the use for soft phone cases (PU?) is a lot better - still absorbs impact but won't grip to everything and pick up all the gunk
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Feb 06 2016
    Honolulu
    I know that some silicone cases are a PITA but believe it or not these are smooth and "non-sticky" if you can use that term.
    I just bought the pair because it was so cheap and just wanted to share my positive experience.
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    I have one of the hard plastic key shells from ECS It did require some trimming(w/a file) to allow the flip-out key to function smoothly, but otherwise fits over the key very tightly. So tightly, in fact, that it was a bit of a chore to remove it to change my key battery.
    ll Audi Sport "Vorsprung Durch Technik"
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Real cf
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Jan 24 2010
    norcal
    Quote Originally Posted by DanKing View Post
    Real cf
    Looks pretty good, where'd you order it from?
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    they make key rings that retract to your belt. Maybe Butter Fingers (OP) should look into one
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by rennwerkes View Post
    Cheap (a few $'s)
