    Oct 23 2015
    Australia
    If an alloy rep fits over the front caliper of a B8 will it fit over a B7 ?
    Looking at Rev Motoring's BBS reps here:http://www.revmotoring.com/wheels-1/...m-style-wheels
    and it shows photos of them fitted to a B8.Can I safely assume that if it fits that front end WITHOUT spacers or adapters,it will fit my B7 also without spacers ?
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Clearing the brakes shouldn't be an issue, but spacers are used for more than just that purpose. With the link you posted the wheels you are considering are 18 x 8.5 ET 35. My B7 came with the Ti package and the stock wheels are 18 x 8 ET43. These are a bit wider, and pushed more outboard as well, so caliper clearance shouldn't be an issue, but you'll be much closer to the edge of the wheelwell, so if you're lowered more than Sport suspension, it may get close.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Veteran Member Three Rings Acme's Avatar
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    Also, I guess you already know but just in case... Bore on the B7 is different and is 57.1... You'll need adapters to fit these wheels.
    2013 Daytona Gray A4 Premium S-Line Quattro 6MT - NAV - bi-xenon - adaptive dampers - Alcantara - Eron's rear view cam
    SOLD! 2008 A4 2.0T Quattro 6MT Unitronic stage 2
    Established Member Two Rings dirtydub01's Avatar
    May 28 2008
    Ohio
    I can almost guarantee you'll need spacers. Just about any concave wheel or anything with a lip on the front of a B7 will need spacers. ECS has the just about the same wheel and they say requires 15mm spacers up front to run them. As for being 66.6 you'll just need the hub rings to make them fit correctly onto your 57.1 hub (ECS includes them).
    https://www.ecstuning.com/Audi-B7_A4...T35/ES2719034/
    Oct 23 2015
    Australia
    Question
    Thanks all
    Quote Originally Posted by papadelogan View Post
    Ive been using this handy calculator and can see your point:http://www.wheel-size.com/calc/?whee...=30mm&scl=50mm
    Quote Originally Posted by Acme View Post
    Thankfully not the other way !
    Quote Originally Posted by dirtydub01 View Post
    I understand the lip pushing the centre back towards the caliper but I would have thought convex would have been more likely to foul the caliper-or am I missing something ?
