Results 1 to 16 of 16
    Veteran Member Three Rings Brens's Avatar
    Jan 07 2012
    B5 S4, MK1 TT 225, 3rd Gen Tacoma, 3rd Gen 4Runner
    Charleston, SC
    B6 to B7 Center Console Swap- Cigarette Lighter Question With Video
    Hey all,
    I did this swap a while ago, and still have yet to get my lighter socket working. Hopefully the video explains it well, but the socket gets weird when something is plugged in. This makes no difference if the car is running or not, key in or key out. The charging device doesn't charge, but the 4 ways turn on, and stay lit. The socket alone doesn't drain the battery or anything, it only acts up when there is a load.
    The B7 ashtray's lighter harness is identical to the B6's stock harness, with the three wires. I just extended these wires so it would reach the ashtray. Not sure why this would cause issue, but the video shows it a little better I hope.
    -Brendan
    Brilliant Black B6 A4 Avant - 5spd 1.8T - Recaro - RNS-E - VMR - Daz - Woody Insides - Clutch/ Tune - Pink Coolant
    Jul 17 2013
    Utah
    Can you confirm with a meter that you have power at the socket and polarity is correct? (positive tip and ground on the sides)
    Jan 07 2012
    Charleston, SC
    Quote Originally Posted by ryanj View Post
    I'll try this later, but I'm confident they are correct, and anyway, if the LED if illuminated I assume its correct as LEDs are polarized.
    -Brendan
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Totally off topic but Brens your in phillipsburg? Im right across the bridge in Easton we should meet up one day. I have some questions about that center console swap. I have one sitting in my basement right now I just need the B7 handbrake to finish the swap. Also Brilliant black B6 A4 Avant.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Seems like you've got some wires crossed. Sound like your power lead is going to the light circuit.
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Jan 07 2012
    Charleston, SC
    Quote Originally Posted by AvantNoir View Post
    And this of course, just means the 3 socket wires, correct? And therefore if one is crossed, it causes some strange reaction in the lighting circuit?
    -Brendan
    Aug 03 2014
    WPB, FL
    This could have been solved in 5 seconds with a multimeter. When I did my swap, the harnes connectors were identical as OP stated but the wires had to be swapped.
    I'm pretty sure I had to swap the wire that powers the light and the wire that powers the socket. OP use a multimeter to verify your connections!
    07 Q7 4.2 S-Line
    02 A4 B6 Avant - Sold
    Jan 07 2012
    Charleston, SC
    Quote Originally Posted by ZERO FRAME GRAB View Post
    Yep! Send me a PM, we can meet sometime.
    -Brendan
    Jan 07 2012
    Charleston, SC
    Quote Originally Posted by Airflite40 View Post
    I see what you mean. However, as I said above, the fact the LED works made me believe it was powered correctly, since LEDs will only light with proper polarization.
    -Brendan
    Jan 07 2012
    Charleston, SC
    Ok, so I checked polarity... it's backwards. I'm a big dum-dum. I'll have to actually pull out the ashtray to see what wires I have backwards.
    Quick Q: Red is pos, brown is ground... what's blue? Voltage across Red-brown is 12v, and across red-blue is 12v.
    -Brendan
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Brown is ground. Red is positive for cigarette/accessories. Grey is positve for light illumination. As stated above where the wires land is different from the B6 and B7. The B6 color brown should land to point 1 on the B7 cigarette lighter. B6 red goes to point 2 on B7 lighter. B6 grey goes to point 3 on B7 lighter.Hope that helps.
    Jan 07 2012
    Charleston, SC
    Quote Originally Posted by Let it snow View Post
    Thanks so much! From which end are you basing the points from? I see Red stays to Red, on the middle pin.
    -Brendan
    May 22 2007
    Santa Monica CA
    Quote Originally Posted by Brens View Post
    3 wires - power, ground (brown), and light. off hand I cant remember the color of the power or light wires. Power is most likely red. You've probably just crossed the power and light wires.
    - - - Updated - - -
    What he said on the colors. If I remember correctly, the light wire is grey with blue stripe.
    Aug 24 2014
    Vermont
    Yes the two outside wires are opposite from the B6 to the B7.
    Jan 07 2012
    Charleston, SC
    Nice and simple then. Thanks again (and to everyone else). I will fix tonight or tomorrow and report back with results.
    Glad this is online now. Unless I didn't see it before, I didn't know this needed to be swapped.
    -Brendan
    Jan 07 2012
    Charleston, SC
    So I swapped the wires over and boom, it works. I could've known sonething was up when the LED light was always on, regardless of if the rest of the interior lights are on (I.e. It's always getting power, and the charger gets none) but oh well.
    Thanks for the help everyone! Nice to have the interior buttoned back up and ready for commuting.
    -Brendan
