Results 1 to 40 of 41
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Block size difference 2.7T Audi vs 3.8 GTR R35 - Massive
    Purely educational thx to Rombotis tuning
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Dec 10 2013
    Borden, Ontario, Canada
    Wow. Look at all the meat between those cylinders
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Sep 07 2012
    Tucson, AZ
    No wonder those r35's can handle so much power... Looks like it's mainly due to that 60 degree block.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    So, you're stuffing that into a b5, right?
    Mar 13 2007
    Montreal
    Quote Originally Posted by DieselElectric View Post
    LOL
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Mar 13 2007
    Montreal
    Stock girdle
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Oct 27 2011
    TOYS
    Philly Suburbs
    How much power/torque you shooting for? You doing any major trans upgrades as well?
    Sep 11 2009
    NE
    Quote Originally Posted by Bordom View Post
    It needs it since it is aluminum!
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    This looks like some photog trickery, it appears the 2.7t block is considerably lower in this pic, and the GTR block is higher up, closer to the camera making it appear much larger. Sort of like when guys kill big game animals and stand in the back of the animal to make it appear much larger then it really is.
    Obviously it's a bigger block, but I think this photo is slightly misleading.
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Mar 13 2007
    Montreal
    1100 whp and around 800 ft/lbs
    Trans is already upgraded, but will be again on the edge.
    Il will be on the edge of what stock gear can take (torque)
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Mar 13 2007
    Montreal
    Quote Originally Posted by S4gasm aka LOTR View Post
    Far from being the point, but i guess if you say so, but i had both in my hands and couldn't believe the difference...
    what bugs me about the Audi 2.7 is the siamese rod journal which i think is very stupid, but worked. Its like nissan engineers didn't take a chance an did 2 complete separate journals...
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by GURUMAN View Post
    LOL
    So is that a yes, Guruman?
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Funny enough I bet you could get that engine to fit in the b5 bay NP.
    Mar 13 2007
    Montreal
    Quote Originally Posted by mikeb17 View Post
    it would fit easier than a LS1
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Oct 27 2011
    TOYS
    Philly Suburbs
    Do you have a build thread for your GTR?
    Jul 07 2009
    Alberta, Canada
    Ya man.
    Classic Brazzers camera work.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    probably had to make them separate for cylinder spacing, because aluminum block.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    You have to understand that the GTR is a much more expensive car to begin with, and Nissan also over-built the engine on purpose, because GTR.
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    How will everything else hold up (driveshafts, axles, etc)?
    Mar 22 2013
    AK
    What's your point ?
    Put the GTR block next to a 6.2 Hellcat or V10 Viper block and it looks puny too
    Jul 20 2014
    San Antonio, TX
    Quote Originally Posted by Drehmoment View Post
    What's your point ?
    I think it was to just highlight how v6 engines have changed (or progressed if that's how you view it haha) over the last 15 years. Iron vs aluminum, narrower v for smoother idle and tighter packaging, taller deck, girdle vs caps, etc
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    One of the GTR's at the shootout over the weekend was pushing 70psi. 196mph in the 1/4.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    What audi did is pretty typical of a 90deg v6. Something similar to the 2.7 would be needed on a 60deg v8. People did do odd fire stuff though.
    What nissan did is interesting. A 60deg v6 would normally be like the 2.7 crank, but without the offset rod journals.
    That looks like it would make the crank both heavier and weaker compared to a typical setup. Maybe the different firing order tunes up some crank harmonics or something so it doesnt see as much stress?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by Austonwerner4 View Post
    I just want to know if the bank lady was there?
    We sooo need another bank lady thread, best thread ever!!!
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    GTRs were running solid numbers at TX2K event. Stock I believe ran 11.6 bunch of them in the 9s and few in the 8s. However this was only if their trans didn't go into limp mode. and all we saw were converted to RWD.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Oct 27 2012
    Lamborfeetes
    Washington
    What's your point ?
    I actually worked on a viper v10 and it was surprisingly small. The engine was also one of the easiest I've ever wrenched on. 6 tools and I removed the engine and tore it apart haha.
    Veteran Member Three Rings Number54's Avatar
    Dec 04 2007
    Switzerland
    Interesting photo and perspective. Keep it coming, these forums are boring lately...
    • Audi A3 3.2 Quattro (8P)
    • Porsche 911 GT3 (996)
    • Audi RS4 (B5)
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Quote Originally Posted by Yuppie View Post
    Electronic center diff. Still awd
    Home of the slowest s4 of 2014
    I buy 2.7 engines. Either short/long blocks. Message me!
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    They do rwd for burnouts then do a pass with awd
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    May 16 2008
    WA
    Performance benefits asides, do you miss a true manual transmission? (not necessarily an 01E, but just having control over that 3rd pedal?)
    I keep debating if I could go DSG, and I just love rev matching and such as it keeps me entertained while driving normally lol
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Quote Originally Posted by zillarob View Post
    what is this bank lady thread we speak of
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    May 16 2008
    WA
    Quote Originally Posted by hibiscusS4 View Post
    Its since been blackhole'd unfortunately:
    http://www.audizine.com/forum/showth...nk-drives-this
    It was pretty awesome, hopefully someone took some screencaps.
    Aug 24 2014
    Newport Beach, CA
    Apparently the bank lady thread is long gone, however I found an overview on another forum:
    1) Guy finds out a hot girl at the bank owns a modded S4
    2) Posts about the girl + s4 on Audizine
    3) Thread explodes with leg humping, picture posting, epic comments, etc
    4) The girl is actually on the forums
    5) Hilarity ensues
    2024 M3 Comp xDrive
    Feb 14 2005
    Quote Originally Posted by rockcandy View Post
    Bring your ass next year. Enough places for you to crash at.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    You're telling me a block from a car designed to defeat the 911 turbo and compete with super cars is bigger than a Audi 2.7?? I would have never guessed . Seriously though it is cool to see the side by side.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Mar 13 2007
    Montreal
    http://www.gtrlife.com/forums/topic/...g-budget-%3Bo/
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Mar 13 2007
    Montreal
    Quote Originally Posted by NOTORIOUS VR View Post
    I understand, but then again I spent so much in the B5's that this GTR is a bargain
    Thread was purely educational on the differences, not that a 2.7 is crap and the VR38 better
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Mar 13 2007
    Montreal
    Quote Originally Posted by Number54 View Post
    I know, I'm still there on occasions
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    May 16 2008
    South Texas
    Do you mean the split pins? Audi did that to reduce the second order vibrations without a balance shaft.
    Mar 13 2007
    Montreal
    Quote Originally Posted by Scotty@Advanced View Post
    ya
    you see, its more a comfort decision than a performance one
    There a reason why a 2.7 wont really pas safely 35 psi
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
