Results 1 to 3 of 3
    Senior Member Two Rings AWD Addict's Avatar
    Nov 06 2013
    Livermore, CA
    rearview mirror came loose
    Has anybody else had to reattach their rear-view mirror? Mine was vibrating for a few days then fell off while driving - dangling loosely by the wiring until I pulled over and unclipped it. I'll need to go buy some epoxy but, before I dive in, I'm wondering if anybody else has done the same thing recently?
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Id just take it to a windshield shop and have them do it. There is a rain sensor in there, wouldn't want to use an adhesive that would effect that.
    Nov 06 2013
    Livermore, CA
    Yeah true. It just seems like an easy fix if I knew where to apply the epoxy. You can see in the pic that everything came apart pretty cleanly. The clear spot in the middle is for the sensor so can I assume the epoxy goes on the dark area surrounding the eye hole?
