Results 1 to 36 of 36
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    Unhappy For those of you with 20s... Ouch!
    What are your wheel and tire specs???
    Just ran a set of 20x9 ET40s (tire size 255-30-20) with a 20mm spacer and discovered some horrendous rubbing where the tire was making contact with my control arm... After about 500 miles... Wow I feel dumb. Thank god I caught it before a blowout.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Wow, ET40 with 20mm spacers is pretty aggressive. I've got 20x10.5 ET30 with 275/30/20 no spacers. Dropped on Bilstein B16s I have no rubbing.
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Veteran Member Three Rings jamin_00's Avatar
    Sep 14 2014
    Essex, UK
    Wow, lucky you spotted this mate!!
    Are you sure it was rubbing? According to here http://www.willtheyfit.com/index.php...et2=28#content "Compared to your existing wheel, this new wheel will have an inner rim which is 27.1mm closer to the suspension strut. The outer rim will poke out 11.1mm more than before." So my set up is closer to the strut as I put your info in including the spacer first.
    And I'm lowered on coilovers too and not got no rubbing issues?
    Audi S5 V6T 3.0 - Black Edition - Stage 2 MRC Tuning - 480bhp 580nm
    Sep 06 2014
    Rochester, NY
    It definitely seems like it was rubbing somewhere. It looks like it was hitting the control arm by the looks of it. The whole inner part of the tread looks as if it was turned on a lathe. I'm lowered only about an inch on KW HAS and had a fresh alignment only a month ago. The opposite side has just very very slight evidence of rubbing which is confusing me.
    IG: @SLU_S5
    Sep 28 2010
    NW NC / DE
    I ran 20x9 ET40 with 20/25 on 255/35/20 dropped 25mm and never an issue. It's not an aggressive setup either. Something is up. That tire pictured only has 500 miles on it?
    IMG_0419 by Audiyos, on Flickr
    Sep 06 2014
    Rochester, NY
    It probably has a total of 2000 miles on it. I bought the setup used. I just took another look and there is plenty of clearance all around. No chance of rubbing anywhere.
    See? Several inches of clearance.
    Possible that I have a shifted belt???
    IG: @SLU_S5
    Sep 06 2014
    Rochester, NY
    Nice wheels btw.
    IG: @SLU_S5
    Sep 06 2014
    Rochester, NY
    What could be causing this strange tire wear???
    IG: @SLU_S5
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Bad alignment. Too much negative camber. Or like you said, bad tire.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by SLU_S5 View Post
    Holy shit. I've never seen anything that bad. I knew it was not the arm. Thought bad tire, bent wheel or a reallyyyyy bad alignment. This is beyond me.
    Sep 06 2014
    Rochester, NY
    Yeah I'm so confused. I really don't think it's rubbing anywhere but it really looks like it is. Bad or loose ball joint? Just had the alignment done... Would a couple of REALLY big pothole impacts cause the tire to crash into the control arm? I mean I did hit a pretty decent sized pothole.
    What's crazy is that I can't seem to find any evidence of rubbing anywhere
    IG: @SLU_S5
    Established Member Two Rings Zonsolo's Avatar
    Sep 14 2015
    OH
    My guess is ran flat for a number of miles. What does the outside tread edge look like? What does the tire off other side of the car look like?
    ►Zonsolo◄
    2011 S5 6MT AWE Touring KW HAS Custom Hypersilver Niche Targas 20x10.5 Hankook 285s
    Senior Member Two Rings Mean Machine's Avatar
    Jan 04 2014
    Manteca - CA
    Looks like Neg Camber
    13 RS5 Cabriolet - Ibis White | Ferrada FR3 20x10.5 - Michelin PSS 295/30ZR20 | AWE Track Extreme | 20% Ceramic Tint | Black Badges |
    08 M3 - Alpine White
    07 RS4 - Avus Silver
    Sep 06 2014
    Rochester, NY
    So... Turns out that my wheel is bent. Like really really ridiculously bent.
    I absolutely jacked a nasty pothole doing about 70 the other day and my guess is that this is the result. Bent wheel and potentially mid-aligned suspension as a result now.
    Would it make any sense to have it repaired? Does anyone have experience with straightening a bent wheel?
    I'll also definitely need a new tire. Would it mess with the AWD if I get only one fresh tire? Should I have both front tires replaced?
    IG: @SLU_S5
    Mar 13 2016
    Ottawa Canada
    Sent from my SM-G900W8 using Tapatalk
    Mar 13 2016
    Ottawa Canada
    I had the same problem with my last set of tires as well, I thought I'd wait until the end of the summer to change them (which I know I stretched pretty far) the inside of the passenger front wheel was the worst. It had that wear but also chunking, which I asked about at the dealership and they chalked it up to bad set of tires. I also had 20mm spacers up front and 25mm rear. I've done 5k on the new tires with the spacers off and don't have any uneven wear. Now my problem is I want the spacers back on but don't know what caused this 😕
    Sep 28 2010
    NW NC / DE
    Bent and not cracked? Achtuning would sell you a new one for about $300. Repair, about $100. John can direct you to a good spot for repair. You're fine to only replace that one tire.
    Sep 06 2014
    Rochester, NY
    Thanks Mops.
    I'll have to get that tire off to know the full extent of the damage I suppose. It is badly bent at the very least.
    $300 for a new wheel doesn't seem like a bad option. I did buy them used but I'm about 95% sure that the set I have are Hartmann RS4 reps. Are there any downsides to having the wheel repaired? Would the repaired wheel be weakened because the metal had been bent previously?
    I do have these S7 Black optics wheels laying around (bought them for my dads A7 and he didn't want them)... Might be time for these. Plus they're OEM and I'd assume that they're a bit stronger/more pothole damage resistant.
    255/35/20s a good tire choice vs the 255/30's?
    Oh decisions decisions.
    IG: @SLU_S5
    Sep 06 2014
    Rochester, NY
    Quote Originally Posted by tpotts85 View Post
    The wear is only happening with spacers??? Crazy! The wear looks the same as mine. What are your wheel specs? Is this happening to just one wheel or a couple of wheels? I'm positive that I have a bent wheel that's contributing to this but I'm still going to have my alignment checked anyway.
    IG: @SLU_S5
    Sep 28 2010
    NW NC / DE
    Not an expert on bent repairs, but it's super common.
    Achtuning is awesome about giving a discount for these situations. They usually run $345 IIRC.
    Love that S7 wheel!! I like the 255/35 for a 9". A bit larger than the OE TD, but NBD. The pic I posted is with 255/35/20. It's a good look, and moar cushion :)
    Mar 13 2016
    Ottawa Canada
    They were potenza s-04's 255/35/19. The dealership service manager said they were not proper spec for the car and I should only use the brand of tire that came on the car from factory. The wear was with both fronts (passenger side was worse), noticed it mid summer and put the fronts on the back and vice versa. I spoke with a few mechanics about this too, they said with that suspension the wheel spacers should be fine.
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    A bent rim cannot cause this type of tire wear, if the rim was bent it would be irregular damage, not a symmetrical lip around the edge of the tire.
    This looks like either something got trapped between the strut and your tire or your alignment is a mile off!
    Wheel repair depends on the quality of the wheel material and the extent of the damage. A forged alloy once bent too far out of shape will have lost its elasticity so bending it back will cause fatigue and cracking.
    A cheap cast alloy wheel....throw it away!
    Slight warping and out of round can be rolled out but where is the safe limit? I wouldn't like to guess.
    Sep 06 2014
    Rochester, NY
    Good points, James.
    I think my best bet is to take my car in for an appointment with my Audi mechanic. This one is really baffling me since there is a ton of clearance everywhere. My guess is that I slammed a pothole, bent the wheel and threw the alignment way off. Who knows, maybe I bent another suspension component in the process...
    Meanwhile, I'll have to decide if I want to buy a replacement wheel and tire, or just move to a different setup all together.
    IG: @SLU_S5
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    This looks a lot more like a Toe problem than a bent rim. Although both could compound each other. Id presume a bad tire and a bad alignment. For what its worth a repaired wheel is largely the same as a new wheel. Depending of course on severity of damage, but most wheel repair places are required to uphold industry standards. Who did your alignment? Ide or Holtz?
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Sep 06 2014
    Rochester, NY
    Monro did the alignment so... yeah... Could be part of the issue. Never had a problem with them before though and I know the guy who did it. He does good work for me. The alignment was done before the new wheels went on and the old tires did not wear like this at all.
    I crushed a pothole last week so my guess is that it bent the wheel and threw off the alignment In one massive blow. I may have a bent control arm or tie rod but who knows really. Dropping my car off at CDI (my go-to Audi indie) on Thursday so we'll see what they say.
    Probably an overall combo of things. Bent wheels, alignment out of wack, and tires. The tires had some camber wear when I bought them (they came on the wheels) and from what I heard, the Hankook Ventus V12s are ok but they aren't the best tire to begin with anyway.
    IG: @SLU_S5
    Apr 02 2015
    Rochester NY
    Ide will do your alignment of 80$ and Matt is great. CDI does good work though not going to discredit them. Changing your wheels will change your alignment slightly depending on diameters and offset etc but not to the degree that you have issues. I personally like the V12 for the money they aren't the best but at their price point they are pretty solid and usually very resilient.
    Feb 27 2014
    Dubai
    Check the subframe alignment too, if you hit the pothole so hard to knock your alignment out, either something is damaged/bent or your subframe has moved throwing your geometry out.
    Is it both inside edges?
    Sep 06 2014
    Rochester, NY
    It's just one inside edge on the left side. All other tires look totally normal.
    IG: @SLU_S5
    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    I see KW HAS in your signature but not adjustable control arms.
    You need adjustable control arms to correct that negative camber issue that you have going on. Chances are your toe is out of spec too, but the excessive inside wear / cording is due to excessive negative camber.
    R8 V10 Supercharged
    8V.2 RS3 grocery getter
    B5 'RS4' Limo & 8L S3
    A few A4 Avants
    Sep 06 2014
    Rochester, NY
    We'll find out more after my indie takes a look on Thursday. I have a feeling that a bent wheel is the biggest culprit and then possible mis-alignment as a result of hitting the pothole. Lowered maybe an inch (if that) Alignment was to spec last month.
    IG: @SLU_S5
    Established Member Two Rings Drew0u812's Avatar
    Apr 02 2014
    1998 3000gt VR4
    Poplar Grove, IL
    That wear is from excessive Toe out. All you need is a little bit of negative camber combined with excessive Toe out to get wear like that.
    A bent wheel will cause scalloped or cupped wear.
    2018 Audi A5 Sportback Prestige
    Sep 06 2014
    Rochester, NY
    It's not totally even all the way around though.
    Do you guys typically set the toe to 0°?
    IG: @SLU_S5
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Quote Originally Posted by Drew0u812 View Post
    This is my guess as well, we see it pretty frequently.
    Senior Member Two Rings Canadianwraith's Avatar
    Dec 30 2014
    London, Ontario
    I believe th op had this happen within 500 miles. he would have had to have a hell of a time steering for the tire to get that worn in that short of distance would he not?
    2009 S5 / Meteor Gray / Fast Intentions / JHM Tune / RS5 Grille / Honeycomb Fogs /20 x 10.5 Niche Targa M129 with 285/30/20 / AWE Filter / 034 Inlet Hose
    Apr 02 2014
    1998 3000gt VR4
    Poplar Grove, IL
    Quote Originally Posted by Canadianwraith View Post
    I would think the car would have been flighty, especially on uneven surface and the steering wheel most likely would have been off center.
    Sent from my XT1585 using Tapatalk
    Apr 02 2015
    Rochester NY
    He also purchased the tires used. Not likely he didn't notice a bit of premature wear, but a few mil head start is a pretty substantial wear, and otherwise indiscernible to most.
