Results 1 to 10 of 10
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    Unhappy Thoughts/Advice - Partout or sell?
    Hi all, I have had my 01 casablanca sedan for 6 years. I bought it in March 2010 with 143K on the clock from the second owner (who only had it for about 5 months/1500 miles). I have daily driven it since then, and it now sits at 219,000 miles. It has been Frankenturbo F4H stage 3 since 156k, and got a new engine with 85k at 170k chassis miles. I considered selling it a couple of times over the past few years, but never did simply because of how much car it is for the money. Finding a car with this much power and practicality means you either have to sacrifice reliability or money. This car has been very reliable for me. Sure little things happen break way too often, but it hasn't exploded or locked up in the middle of the morning commute. That said, the little things have been piling up and I have neither the time nor energy to deal with it anymore, and I can't justify dumping any more money into it. Now I'm just trying to determine if somebody else does want to bring it back to life. After writing this I am now feeling fully sentimental and mildly depressed.
    Pictured right - hanging with a fellow casa some years back - photo courtesy Bimmerchop
    The good:
    Casablanca white, RS4 front bumper, dead sexy (right?), huge mod list, never abused. The fact that I've had the same Vast stage 3 clutch and RS4 pressure plate for 73,000 miles should be a testament to my driving style. Haven't launched in 2+ years, but still holds on a solid 1-2 shift.
    The bad:
    Turbos don't hit full boost anymore - depending on the ambient air temperature, they'll hit 18-21psi. Not sure if it's a wastegate issue or if they're just tired after over 60,000 miles.
    219k chassis miles daily driven year round in MA and CT for 15 years. Far from a Cali car - some rust spots showing up on the body and a nice key mark on the driver's side. Still a beautiful "10 foot out" car.
    Little things - bad ABS ring, bad axle, exhaust leak, vacuum leak, needs rotors and pads on all four corners, probably needs a fresh tune.
    Aging parts - clutch and timing belt should be done soon, bilstein pss9s are about a million years old though they feel good still.
    Mods list:
    Engine/Drivetrain:
    Frankenturbo F4H
    OEM RS4 Inlets
    Vast 90mm MAF
    AWE SMICs
    62lb EV14 Injectors
    Walbro 255lph Fuel Pump
    Devil’s Own water meth kit with #7 nozzles
    AAN lines from pump to nozzles
    Aluminum Bi-Pipes
    FSI Coilpack Conversion
    Black Powdercoated Valve Covers
    Updated Vented Oil Cap
    Samco TBB
    710N Diverter Valves
    Hallman MBC
    Techtonics 2.5” catless downpipes
    Vibrant 3” exhaust
    Vast poly snub
    Stern Soft Engine Mounts
    Stern Transmission Mounts
    Vast Stage 3 Clutch
    RS4 Pressure Plate
    Vast EFK
    Low temp afterrun coolant switch
    Suspension/Wheels:
    H-Sport Front and Rear Sways
    Bilstein PSS9 Coils
    18x8 Bremmerkraft BR05
    Hankook Ventus V12 evo 2 tires 225/40/18
    Exterior:
    OEM RS4 Front Bumper
    OEM RS4 Grille
    35w HID yellow fogs (and independent fog modded relay)
    Depo D2S Headlights w/ 6000k 55w HID (also have a set of OEM Valeo E-codes that need some TLC)
    Tints - 35% sides, 20% rear
    Black vinyl applied to roof
    Interior:
    White suede wrapped beltline trim
    Black plast-dipped hazard and shifter surrounds
    OEM RS4 air leather shift knob
    Shift-style leather boot with white stitching
    Podi steering column mount w/ VEI digital boost gauge with peak recall
    A-pillar mount with Innovative LC-1 wideband
    B6 rearview mirror w/ compass
    SRP pedals (black grid)
    Perfect center LCD display and functioning cup holder!
    May 30 2015
    canada
    keep it! those are all easy/cheap fixes, apart from the turbos potentially needing a replacement soon..
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Car looks really good. Keep it and fix the vacuum leak and that should fix the boost leak and your lower than normal boost level.
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    I remind myself : Each and every B5 S4 was built in Germany, put on a boat and brought to the US and others.
    After the kids that blew them up, crashed them, parted them out, etc. there are becoming fewer than you'd expect.
    My .02 cents.
    Mar 22 2013
    AK
    Part it and move on
    Veteran Member Three Rings kingkhalilz's Avatar
    Jan 31 2013
    Mchigan
    If you dont have a specific make and model chosen for your next car, then i say keep the s. It will be hard finding something else that you will be happy with.
    Dec 10 2013
    Borden, Ontario, Canada
    Keep it. How many Casa S4's do you see anymore? Partout is not an option
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Active Member Two Rings Pjbash's Avatar
    Aug 05 2015
    Denver co
    Keep it or sell it to me! Lol jk but plenty of people love the B5 s4! If you don't want it someone else will.
    Aug 21 2007
    Quote Originally Posted by Corradovolksb View Post
    The problem is that the boost issue existed before vacuum problem.
    Quote Originally Posted by reverse.rake View Post
    Yes, all cheap and easy except for the wildcard of the turbos..
    Quote Originally Posted by kingkhalilz View Post
    I was thinking hard about a B8 S4 with DSG. Similar power, less thrilling, more modern. And back into a car payment...
    I could easily sink another $1000 into this car and still have a 15 year old dog that hits 18psi at 4900rpm. That's what I worry about.
    Sep 14 2005
    NC
    trade me straight up??
