Results 1 to 11 of 11
    Feb 16 2016
    Chicago
    Facelift tail lights on 2013
    I'm planning on installing the facelift tail lights on my 2013 A7. Most posts I see are in regards to retrofitting the Euro dynamic sweeping lights, which require more work, and I believe additional parts.
    If I simply want to install the US Facelift (2016) tail lights onto my A7, will there be a lot of problems, or do I need any different components other than the tail lights? (I am having a shop install them)
    Feb 26 2010
    Los Angeles, CA, USA
    Quote Originally Posted by kamek89 View Post
    I believe its a direct fit...so no additional components/modules need to be installed.
    Don't know if you need to code the post-facelift taillights via VCDS.
    I'm having my 2016 RS7 upgraded to Euro Tailights with dynamic turn signals...will post videos when installed by my shop in a couple of weeks.
    The new Euro tailights with dynamic turn signals DO have additional wiring harness/modules that need to be installed in addition to coding.
    Senior Member Two Rings Thisisnoise's Avatar
    Oct 16 2012
    Los Angeles CA
    I did the euro taillights as I found them on classifieds for a good deal - any reason you don't want to install the sweeping euros? Install/coding was relatively easy
    2014 S7 Black Pearl- Black Optic- HRE FF01 -Michelin SS - APR Downpipes- RS7 turbos - APR stage 3 Ecu/Tcu-Alpha cooler- AWE Track Exhaust -RS7 Grille and Bumper - TAG Blackout Emblems - TAG Painted Reflectors - Euro Facelift Taillights - ABT CF Spoiler - Eurocode Sways /Links - Eurocode inserts - XPEL Stealth- Opticoat- Optiguard - VIP Stinger radar and laser - Alu Kruz - Carbon Fiber FB steering wheel- CF front diffuser -CF mirror covers
    Feb 11 2016
    earth
    Quote Originally Posted by Thisisnoise View Post
    Do you mind sharing the total cost and steps involved?
    Feb 16 2016
    Chicago
    It's not that I don't want to, but it requires more parts right? Not just simply coding? I got rear ended the other day (after only owning the car for 3 weeks). It's not bad though, just new bumper and the tail lights chipped on the corners so I will be getting new ones. The body shop I use said they can install the 2016's if I want.
    If it's just as simple as coding, then I'm all for the sweeping lights, however, from what I've read it requires more parts (as chucky0731 said above), which i'm not sure the body shop can justify to the insurance.
    Oct 16 2012
    Los Angeles CA
    Alex at europrice has a package - from what I remember was just a couple additional modules/wiring harness and some coding . He might be able to send you instructions before you buy but I remember it being generally easy to install
    Feb 16 2016
    Chicago
    So turns out the 2016 tail lights have different connectors. For those that did this swap, what did you do to go around this? Thanks!
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    You apparently need a wiring harness.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Feb 16 2016
    Chicago
    Quote Originally Posted by Brooklyn View Post
    I contacted Alex, hopefully he can help me out.
    Someone replied earlier saying it was a direct fit without anything extra, so that's what I went with. Now I know that that isn't the case...
    Apr 13 2016
    Fresno, CA
    Did you pick these up from the dealer or online also, can you by chance share the part#'s?
    Feb 26 2010
    ANy update on your retrofit?
    Was Alex of Europrice able to help you out with wiring harness? Did you have to recode with VCDS?
