Results 1 to 4 of 4
    Registered Member One Ring deepMN's Avatar
    Mar 19 2016
    Minnesota
    Question Need Instructions How To Replace Thermostat & Water Pump in 2010 A6 Quattro 3.0T
    Hello Everyone,
    My Car: 2010 Audi A6 Quattro 3.0T Sedan - 108,000
    I need to replace the thermostat and water pump. I scoured the web/YouTube for instructions specific to my car, but was only able to find ones for Q7, which I watched. Hoping you can help me.
    I noticed there is less room between the radiator and the engine in my A6, than in Q7, so I am concerned Q7 instructions might not work.
    My biggest question: is is possible to do without having to remove the front bumper/radiator, or do I have to remove them? Any type of advice/instructions would be greatly appreciated!
    Thank you very much!!
    Junior Member Two Rings TheAlphadog's Avatar
    Nov 03 2015
    Another car
    Cedar Rapids, IA
    Advice:
    My 2011 A6 3.0T (60,000 miles) service history showed that the thermostat was replaced around 6K miles by the dealership. Sure enough, 3 weeks after buying the car (private sale), the thermostat needed to be replaced. When the problem happened last November, it happened quick and I knew there was no way out of a repair.
    I took my car into my local indy shop and they quoted me a price of around $1350. This included the following:
    1) All labor -- that is, labor to pull the front end, diagnose, inspect, repair and put back together. Labor rate was $105 an hour.
    2) New gaskets, where needed, for water pump & supercharger.
    3) New belts (not needed but what the heck for $120-ish bucks).
    4) New thermostat & water pump.
    To me, it was worth having the shop do this repair. I'm mechanically inclined, but I just don't have the tools, garage space, or time to do this type of repair. I don't have the cost breakdown in front of me, but labor time to do the repair was around 8 hours, if I recall. Parts cost was around $500 of the total cost. And, I have peace of mind that my indy shop did the repair correctly. If you are considering doing the repair yourself, make sure you inspect and consider replacing the parts I mentioned above.
    Jan 24 2010
    Paramus,NJ USA
    sounds like you got taken for a ride cause the nose doesnt need to come off to do a water pump or thermostat in that car with a 3.0t engine.It can be done without pulling bumper,radiator or rad support.Biggest pain in the ass is the tensioner for the supercharger belt thats about it.Once the charger is off its a piece of cake.Water pump will come out as well just needs to be rotated a bit but it will come out.
    Quote Originally Posted by TheAlphadog View Post
    Advice:
    Ziddy Autowerks
    Established Member Two Rings mrismail's Avatar
    Oct 27 2014
    Las Vegas, NV
    EDIT: Video added.
    I have a video bookmarked on my browser. I'll post here. It's a DIY on how to replace the thermostat and carbon cleaning on the 3.2 C6 A6 which should be relatively the same on the 3.0.
    Sent from my Galaxy S7 Edge
    2011 3.2L S-Line Premium Plus
    Current mods:
    ST Coilovers | G6 3000K LED Fog Lights | Blacked out with PlastiDip: Chrome trim, front grill, rear emblem, corner lights | Quad tips | 25% 3M tint all around | 4000K LED license plate | 20x10 Rear and 20x9 Front Wheels| Black vinyl wrapped roof | Rear trunk spoiler | Rear window spoiler | Tinted rear lights | SLine steering wheel with paddle shifters |
