Results 1 to 7 of 7
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    How Do You All Prefer Doing Tire Rotations?
    The Owners Manual only provides one option, which is to move both rear tires to the front, and both front tires to the rear
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    I was under impression that we should do diagonal rotations, and maybe even flip tire on rim to get most life out of it.
    Im running my tires for 5 years now, no rotation, 20k. Its time for them to go anyway. They served well. And were cheap as shit. Falken ftw
    Dec 27 2014
    2013 Audi Q5 3.0T
    I wish I had the facilities to be able to flip tire on rim :D
    Tires are relatively new, installed them back in September of last year. Tread wear appears okay. However, its been a little over 4,000 miles ever since installing them, should rotate them.
    Current:
    70,xxx Miles
    182,xxx Miles
    Jun 10 2013
    United States
    Move rear tires to front, my front tires to rear and swap sides. This assumes you have non directional tires.
    Dec 27 2014
    2013 Audi Q5 3.0T
    My Continental's are asymmetrical. Time for the cross-pattern.
    Current:
    70,xxx Miles
    182,xxx Miles
    Sep 11 2009
    NE
    yeah, if you have directional tires you're screwed and can only do back/front swap. "investing" into cheaper tires might make more sense if you actually care to rotate the tires properly :)
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    Quote Originally Posted by glennda5id View Post
    Quote Originally Posted by arjun90 View Post
    Yep, the "rearward cross." Best option, I think, for non-directional, asymmetrical tires. Extreme specificity:
    - RR to RF
    - LR to LF
    - RF to LR
    - LF to RR
    Quote Originally Posted by julex View Post
    Well, yes, if they're directional and asymmetrical, you're screwed. But if the tires are symmetrical, whether directional or not, you can unmount and flip for ultimate rotation possibilities. In fact, many expensive and/or high performance tires such as the Michelin Pilot Super Sport are asymmetrical and non-directional, or like the Hankook Ventus RS3 are symmetrical (and directional in the case of the RS3), so the idea of going "cheaper" just for the ability to rotate is somewhat of a silly notion.
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
