Results 1 to 10 of 10
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    My first bash at a 1/4 mile run
    Was a pretty rubbish day weather wise,but good experience none the less
    Couldn't get traction most of the day,but finally managed one reasonable run
    12.26 @116.86 :)
    Not bad for a first time I guess
    revo stage 1+ ,Milltek ValveSonic,revo intake
    99ron UK fuel blended with 3 litres of ethanol in a full tank so I could run the 100RON revo file
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Three Rings ShopVac's Avatar
    Feb 02 2016
    BMW M4 Comp / Abarth 124 Spider / RDX A-Spec / Jetta / Elantra
    Pittsburgh
    I'd say that's pretty respectable for your first runs...
    __________________________________________________ _____
    Proud owner of four turbos and one supercharger.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Nice run! I was recently in London last week on business and saw beautiful Audis. Whereabouts did you make your runs?
    Feb 05 2016
    UK
    Cheers PPL :)
    I ran at Santapod near Wellingborough
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    That's a very impressive E.T. that you managed. Good for you and your machine.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    That 60ft needs to come down!!!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Feb 05 2016
    UK
    Quote Originally Posted by fitzydude View Post
    It certainly does,but best I could do in the conditions.
    Mar 28 2014
    Quote Originally Posted by xpoweruk View Post
    Nice times! Are you running with a stock clutch or a performance clutch? If so, which one?
    2014 S5 APR Ultracharged
    Feb 05 2016
    UK
    Stock at the moment.
    I did try a performance one,but it failed(pressure plate)
    Mar 28 2014
    What RPM did you launch at?
    What causes a pressure plate to fail? Which performance clutch did you go with?
