Results 1 to 6 of 6
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    17Z and 18Z Brembo 6 POT Calipers
    I currently have one set of 17Z and one set of 18Z Calipers
    The 17Z were from an 05 Touareg with 133K.
    These will complete a 330mm BBK with only modifying the rotors.
    The 18Z were pulled from a 06 Cayenne S with 78K.
    These will complete a 345mm BBK. You will need to bore out the hub and bolt holes on the rotors as well as grinding the upright a bit for the rotors to fit.
    I can include mounting hardware, stainless lines and anything else to complete the BBK.
    Feel free to email me.
    Austonwerner @ gmail.com
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    How much for the 18z
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Bump
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Trade your 18z for bhf 4.2 shortblock w/cyl. Heads?
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Quote Originally Posted by S4orgy View Post
    No sorry. I have no use.
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    18Z are sold.
    Still have a set of 17Z
