Results 1 to 8 of 8
    Established Member Two Rings Jg3's Avatar
    Jun 11 2015
    2005 A4 B6 3.0 cabriolet
    SGV
    New turbo install smoking help please
    Ok I have a 2012 a4 Quattro, my wastegate was bad so I bought a new turbo,I was told it was easy so I installed it myself,I believe I did everything correct but when I turned it on it started sputtering and blowing white smoke from turbo. What could've i done wrong? I just took old one out and put new one in going by Alldata instruction. I did try adjusting my exhaust since one stuck out more than other. Help please need my baby back on the road.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    I used this thread when replacing mine for the same reason.
    http://www.audizine.com/forum/showth...4-Installation
    I would suspect that you have double checked that you have crush washers on both sides of all banjo bolts, and that your oil and coolant lines are in the right places. If not, double check those, as well as your DV and N75.
    Was the car burning oil prior to the swap? Where did you get the turbo? Are you dripping coolant or oil on anything hot? Is the engine sputtering, as in misfiring? Do you have a VCDS or Carista?
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jun 11 2015
    SGV
    Ok I fixed it I forgot to take a clamp off a coolant hose. I know I'm a idiot. But is there supposed to be a 500 difference in boost specified and actual? Based on apr mobile logging? I seem to be dripping coolant too
    Jun 11 2015
    SGV
    Thanks by the way
    May 25 2011
    Norway
    If you swapped the turbo by yourself and the worst mistake you made is to leave a clamp on a hose, you're doing well in my opinion :)
    At which rpm are you seeing the boost difference? On my B7, the Revo file would ask for loads of boost low down around spool (1600-2000ish rpm iirc) , probably to improve response. I always had a difference in that range but not much of a difference above that rpm range.
    Oct 23 2014
    _
    kvittrafn makes a good point; and judging by the fact that you have the apr dongle, I have to ask if you're tuned? He is also right in the fact that you're doing well if that's the only hiccup you had.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jun 11 2015
    SGV
    Thanks guys, I was feeling a lil dumb about that mistake but now you guys pumped me up feel good about myself now. Think I'm ready to rebuild an engine J.K.lol I'm nowhere near ready for that. I'll check on the rpm in a bit and update
    Jun 11 2015
    SGV
    I have APR stage 1, injen cai, recirculating bov, Billy boat double dual exhaust(which I now notice has more of a rumble sound after turbo install hope didn't screw up something), 2" Eibach springs, 20" Stance rims,
