Results 1 to 16 of 16
    Sep 29 2007
    02 S4 /07 S4 / 11 Q5 / 16 S3
    Clarkston, MI
    Home link problems
    Has anyone experienced that they cannot get their home link garage doors to work? The same garage openers worked fine on my 02 & 07 S4 and on both our 11 & 16 Q5's but I cannot get this darn S3 to hold either of the two doors. It's driving me nuts! I have tried every instruction I can find and once in a while it holds it for like once and then it never works again. I assume it's a rolling number but again it's worked on 4 other audits without a problem ever for the past 8 years.
    16 S3 with awe exhaust, usp downpipe, JB4
    2000 911 C2
    Sold 02 S4 with Apr stage 1 / millitek catback
    Sold-07 S4 with DTM kit, JHM tune, stasis exhaust, 19" VMR 710,
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Sounds like a defective Homelink module.
    Sep 29 2007
    Clarkston, MI
    Quote Originally Posted by Luis_Heineken View Post
    That's what I am wondering as well, it seems now it's holding one of the two doors at least.
    2000 911 C2
    Mar 21 2015
    I know the S4 ones are hard as hell to program. It was a pain.
    Apr 05 2016
    Northern California
    My 2016 A3 e-tron port-installed Homelink unit will only accept one of my 2 garage doors. And these same 2 door store perfectly in my 2007 S6, 2006 A3 and 2016 Toyota Tacoma!
    WTF Audi?
    Apr 06 2016
    Cincinnati, OH
    I've had trouble with my homelink setup as well. I pretty much gave up on it and just use the clicker/opener now, unfortunately.
    Mar 21 2015
    I just got my homelink module replaced and programmed it yesterday. Still does the same thing the old one did. When I leave the house homelink will close the door just fine but when I come home it won't open it. Drives me crazy.
    Sep 29 2007
    Clarkston, MI
    So I am not the only one lol, I to gave up
    2000 911 C2
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    Im having the same problem with mine. Any one find a solution?
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I had the dealer install their HomeLink on my '16 S3 Prestige. The only issue I have is to open the for I have to be almost right in front of it and hold the button down for probably 3-4 seconds to get the door to open. To close, I can just tap it and it closes.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    Quote Originally Posted by Cairo94507 View Post
    My cars are much older (2001 S4 and A6), but a while ago, I started having issues where it was difficult to get my garage door to open when the car was outside of the garage using Homelink. I ended up extending the wire antenna from the garage door opener from being say 1.5' to around 15', and that fixed the issue. The antenna wire is small gauge, and I tie wrapped the longer wire to the conduit going across the garage to the opener so it is really not noticeable. Anyway, main thing is that if it seems like there is a sensitivity issue trying to open the garage door from the outside, then maybe try adding on wire to the antenna at least as a quick test. - Jim
    Active Member Two Rings jaydub's Avatar
    Aug 12 2004
    Las Vegas, NV
    It sounds similar to the problem I had, except that in my case, my opener was too new for the cars to program. My garage door opener is a brand new one that uses Homelink version 5 and has its own iPhone app, wifi connectivity, etc. Once it was installed, I found that I couldn't program the aftermarket Homelink mirrors in my cars without using a bridge device that basically translates the version 3 signal to version 5. My cars both used mirrors that were Homelink version 3 compatible. However, once I bought the appropriate bridge device for my opener and programmed it accordingly, it worked just fine. I didn't need the bridge with my '16 A3 or the aftermarket Homelink 4 mirror in my wife's car.
    That said, I wonder if the transmitter in your S3 is newer than what your garage door can handle. If that's the case, I doubt that a bridge device would do much good.
    Sep 29 2007
    Clarkston, MI
    in my case i have two doors with the same old door opener, one works fine, the other doesnt. my wifes 2016 q5 opens both no problem. makes no sense
    2000 911 C2
    Aug 12 2004
    Las Vegas, NV
    Ahh, I see. You're right; it's odd that the Q5 has no issues whereas the S3 does. At least it seems like the S3 module is working properly.
    The only other thing I can suggest is that there's some interference with the second door.
    Dec 22 2015
    I have a brand new LiftMaster jackshaft opener on my door. But I do like the antenna extension suggestion and will give that a try.
    Feb 14 2015
    Atlanta, GA
    Quote Originally Posted by tekkie View Post
    Directions and other videos for e-tron demonstrate people pointing their remotes at the front of the grille while HomeLink is ready to learn. NOTHING worked for me until I was in my driver seat with the engine running and pointing my remote centimeters away from the HomeLink unit on the sunroof.
    WORKS LIKE A CHAMP. Never any issues opening with HomeLink since programming.
