Results 1 to 9 of 9
    Feb 25 2016
    Plymouth mi
    Manual exhaust on automatic?
    I have a 2000 s4 with Trip and I just bought a 2001 parts car, but it is a manual. I know the Exhaust is different, but what kind of issues should I expect? I want to take downpipes and the full exhaust?
    The parts car also has fuel injectors and a upgraded fuel pump, with all these parts swapped to my car, would this be a stage 2? I would need another tune, correct?
    Feb 23 2014
    Charlottesville, VA
    Quote Originally Posted by robbyptown View Post
    The biggest issue is that downpipes from the 6 speed will not fit around the tip.
    As for being stage 2. There are some different guides here explaining the stages, but most people will refer to stage 1 as new software, stage 2 as software plus exhaust (some will call a cat back stage 2 and a turbo back 2+), and stage 3 is upgraded turbos with appropriate sprouting mods.
    Sent from my XT1254 using Tapatalk
    Feb 25 2016
    Plymouth mi
    They will not fit even with modification?
    I have stage 1 software now
    Oct 27 2011
    TOYS
    Philly Suburbs
    Of course you can mod them to make them fit. But after the time and effort you might just be better off buying auto downpipes from the start.
    Aug 06 2008
    Canadia
    Vague answers are all there is for this question unfortunately
    the B5 S4 is like the mafia... there is only one way out!
    Jun 08 2014
    Vancouver, Washington
    6mt downpipes WILL NOT fit. At all. I had my engine out (tip) and also had a set of manual downpipes. The manual ones are much too small and are shaped differently.
    Feb 25 2016
    Plymouth mi
    Ok, so better off selling these to get proper dps
    Sep 18 2015
    Indianapolis
    Robby I have a full set of 3" downpipes and 3" exhaust for a tip
    Established Member Two Rings kewe24's Avatar
    Dec 10 2011
    Des Plaines IL
    swap the manual trans to your car
