Originally Posted by
GrapeBandit
thats one car, and you can do 800 on a v6, vr6, i5 or an i4.
my point exactly, the cost. why pay more when you can have the same outcome for less? only factor of the v8 swap is to say "I have a 4.2". whoopdi fucking doo.
it reminds me of the clowns who want to swap tdi engines into everything, just to save a few pennies on gas and the "I have a tdi swap" factor
if you are going to swap and keep it in the family, at least use one of the better engines. vr6 or i5.
if you are going out of the family, theres only 3 choices: 1jz, 1.5jz, or 2jz
Man, relax. It's all about choice here.
If you're referring to cost, check how much a VR6T costs. It isn't cheap - a buddy of mine is on one in a 2002 B5.5 VW Passat Syncro. The cost of custom parts required to even bolt in a stock VR6 without boosting it is huge.
Flywheel
Adapter plate
Starter motor
Oil pan
Mounts.
Harness.
None of these parts are off the shelf, and this is only the beginning. You won't be running air either. I wouldn't go this route, I would rather stick with a 2.7T and go single turbo. The main reason the VR6T swap gets done is ease of snail replacement. But, I would not knock those that go the VR6T route - it's guys like this that are pushing boundaries, and developing power solutions for an ageing platform.
The 07K I5 is not a cheap or easy swap either, seeing as you're looking at cost. Give Hank at Iroz Motorsport a call, get a quote, and see if you'll still see it as financially viable.
Let's be real here - 800hp from a V8T is not the same as 800hp from a 1.8T. Very different. Which engine do you reckon would be more stressed at this power level?
The same outcome for less in an I5?? Lol...by the time you get that motor sitting a B5 chassis, and running stock (naturally-aspirated) with a custom harness, you'd have spent well over $11,000. Then boost it - at the 800hp power level you opted for, this will need to be a built motor, big injectors, custom fuel rail, then find a shop that can tune it. Another conservative $15K or more.
The 07K is a great motor, but if cost is your consideration, then you wouldn't even include this in your options.
