Last weekend I drove over a train track pretty hard, which didn't sound or feel good at all, but everything seemed normal with my A4 afterwards. That night while driving I noticed flickering from the right headlight after each time I pressed and released the brakes. When I inspected the headlights, both were shining as bright as ever. A few days later, I noticed the flickering as soon as I cranked her up and this time when I inspected the right headlight was out. When I shut the car down and crank it back up, the light briefly works until it flickers and dims again. On one instance my dash showed the "dipped right bulb" warning. I ran Vag-com diagnostics on it and received the following fault:
02770 - Headlight Swivel Module; Right
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 254
Reset counter: 34
Time Indication: 0
I read online that maybe my projector lense is out of alignment and I can manually align it. Is this likely my problem? If so, how do I do that?
Thanks in advance for feedback
