Sup AZ, recently noticed some drive line vibes @ 40-60 mph around 2000 - 2500 rpm in 4th 5th and 6th gear. The vibes seem to be emanating from the bottom of the seat up to the steering wheel. It happens while accelerating and decelerating w/ and w/o brakes applied.
Recent work include all OE parts- clutch/DMF, front wheel bearings, all front control arms, trans mount, engine mounts. Before the work there was no drive line vibration. The engine mounts were leaking, the rest were ok.
In the pic it looks like the driveshaft is sagging or bowed in the middle. Everything else is tight like axles front/rear, steering rack bolts, all the mounts, sub frame bolts, tie rods, ball joints, snub mount are all new, OE and in good condition.
Have a look at this pic, let me know if you guys have experienced this before. And oh 2004 A4 1.8T AMB 6MT
Notice how the rubber is bulged at the bottom of the rubber mount, shouldn't it be uniform all the way around the drive shaft?
