    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Brembo 18z BBK 345mm Rotors Complete $850.00 Shipped CONUS
    ) 2006 Porsche Cayenne S Brembo Right and Left 18z calipers
    2) Brand New 18z Mounting Hardware for B5/B6/b7 S4/Allroad/A6/A3 uprights
    (4x Metric Flange Bolts (10.9 hardness) , 4x Steel Sleeves, 4x Metric Flange locking nuts (10.9 hardness)
    3) Brand New Front Brake Lines (non banjo :) )
    4) OEM 17z Pads Brembo G95535193905 Ceramic Brake Pads with about 90% life remaining with pads sensors intact.
    5) Brand new ML55 Right and Left 345x32mm Rotors (All the modifications have been made to mount to your Audi 5x112 hub!)
    6) Shipping VIA Fedex Ground to CONUS
    The calipers have not been rebuilt, there is no need, they were removed from a 2006 model with 30K miles in southern Florida. All of the boots are intact, pistons are without chips or cracks. The only reason to rebuild or refinish them is if you were to powdercoat them.
    The 17z pad is used on the 18z caliper instead of the 18z pad because of the overhang with the larger pad on the 345mm rotor
    Depending on how quickly payment is received they can go out the next day (sometimes the same day) at the earliest. The price is $850 shipped. I can assure you what you will receive is plug and play ready, no need to worry about switching lines or modification of the rotors. You will most likely need to grind the uprights to ensure clearance of the inside rotor. I have sold over 15 of these kits so far with very good feedback. (there was one exception...which I believe I made right by the buyer :(
    **All threads have been cleaned thoroughly and seal tightly, no stripped threads on either the bleeders or the cross-over pipes.
    Cost: $850 Shipped (EXCLUDING PAYPAL FEES if APPLICABLE)
    FAQ:
    Pick-up: Available 11030...can't meet you, you have to come to me.
    Shipping options: No they won't fit in a flat rate box...so it's not possible to ship via USPS large flat rate box.
    Price: Negotiable, please don't insult me. If interested in making an offer please email me with your shipping address (prefer commercial, but residential will do) and a telephone number.
    Trades, possible: 1) Low mileage BEL engine with all accessories
    2) brand new or rebuilt no mileage coilover set-up for the B5 S4
    Will these fit under 17" AVUS: YES! With 20mm spacers at all four corners.
    List Date: 3/19/2016
    For more info, click here to view the original listing: Brembo 18z BBK 345mm Rotors Complete $850.00 Shipped CONUS
    On Sale For: $850.00
    Jan 01 2012
    2004 A4 Avant
    CO
    these will not fit under 17" avus's without serious modification (grinding of caliper) . my 17z's barely fit under my avus's, they scrape the wheel weights a little bit.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    pictures updated.
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
    Jul 30 2013
    South Florida to Nor Cal
    This is a good price...A good junk yard find would make this price difficult (though surprised no SS lines). GLWS
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Sold
    IG: dr.yellowbird
