    Established Member Two Rings johnwpowell's Avatar
    Apr 13 2014
    VA
    S5 manual rev matching
    I wanted to check with you all if my S5 is normal or if something is wrong. When I disengage the clutch, the engine and RPM shoots up briefly. My tech at the dealer says its rev matching and by design, but it is weird. Anyone else have this?
    Senior Member Three Rings bruno7652's Avatar
    Dec 22 2014
    2005 Dodge Ram 1500 SB Hemi Sports Pkg
    So.Cal.
    No, I have never noticed it, I will look for it and get back to you.
    2013 S5 Phantom Black 6MT
    |Lifetime Sirius|Bilstein|AWE|Apikol|E C|JHM|BFI|CR-15|BBS|Michelin|BlackVue 750s-2CH|StopTech BBK|Roc Euro CAI|
    |034 stage II+|APR CPS|
    Feb 09 2016
    co
    Yes i have it too, it's not a significant rev jump maybe only 500-700rpm
    Apr 13 2014
    VA
    Yeah exactly. If I disengage at say 1500, it'll jump up to 2000, hang for a second and then drop
    Established Member Two Rings Tom Servo's Avatar
    Jul 20 2014
    Somewhere, South Carolina
    Same for me too, except that my engine wants to rev several times, For example, when I would be coming up to a stoplight or something like that, as soon as I would push the clutch in to coast to a stop my engine would rev up to around 700 or so RPM and back to idle and back up at least three times and then idle normaly ,and this was without me touching the throttle. I never found the cause and it wasn't all the time. It was an annoyance but I never tried to find the reason.
