Results 1 to 40 of 42
    Aug 06 2014
    California
    Shut down on freeway
    Need help! 2010 Audi s4 Manual 55k. I was driving on the freeway normal driving felt a small jerk at the same time no more power. Rpm started to drop and no response from the accelerator. Pulled off to the side and now engine doesn't turn over. No codes no nothing. Towed it home and it starts for a instant and shuts down. Any help is appreciated thank you
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    throwing any codes?
    edit, just saw you said no code. My bad!
    Maybe I'm thinking it could be fuel related, perhaps the fuel pump.. But strange it wouldn't turn over right after maybe electrical then.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Aug 06 2014
    California
    That's what I was thinking. I have run some e85 in my car. A conservative mixture a few times
    May 20 2010
    Serpentine belt? I remember something happened about a decade ago on my Pontiac Grand Prix GTP (3.8 supercharged). The serpentine belt snapped and wrapped up around the supercharger. I felt like you did--no power whatsoever, no matter how much I gunned it. Mine did start up because I only drove it a short distance. Possible you may have run out of battery if this is the case (since alternator wasn't turning).
    Go venture a look in case.
    Mar 07 2015
    Ottawa, Ontario
    Almost sounds fuel related. Had a fuel pump relay go on my Prelude and it would start and run for a few seconds and shut off.
    Jul 05 2014
    Houston
    What if the fuel level sensor failed and it ran out of fuel (I had a Ford Probe do this). When is the last time you filled up? Still does not explain the failure to turn over right after..
    Nov 20 2014
    New York
    If it was fuel related I'd think it would throw the EPC light on with a fuel related code
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    First off Does the car have power? Does the car crank at all? Those are the basic questions we need answers to first
    Aug 06 2014
    California
    Put gas in it yesterday almost a half tank now. It turns over very briefly then dies. Car tries to start again fails and shuts down completely. I am Giac stage 2 as well
    Aug 06 2014
    California
    Car has power it does crank. It fired for a moment and shuts down again
    Mar 07 2015
    Ottawa, Ontario
    Did a quick search and found this http://www.audiforums.com/forum/b6-m...arting-177023/
    Turns out it was a fuel pump. Maybe give it a read to see if your symptoms are similar.
    Jul 05 2014
    Houston
    Time to get the starting fluid and spray it in the intake to see if it starts and stays running runs.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by fitzydude View Post
    This. Just pull the intake off the Throttle body and have a friend help you. Someone crank while someone spray. But you have to Judge the spray don't just go spraying the crap out it it. Spray in Burst's quick at first until it fires and long and longer as it starts or wants to fire. Its a learning process you will see
    Aug 06 2014
    California
    Just dropped it off to the shop. I'll let you guys know what they find. Thanks for all the help
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    Wow this sounds exactly like what happened to me today. After a sudden snap while downshifting off the freeway the steering lost power assist, and the car felt way off.
    Popped and hood and found my serpentine belt shredded and my new APR pulley split in half.
    Had a flatbed pick it up and now it's at my shop till Monday. They don't know if the APR belt or OEM belt gave first so once we figure that out it either gets repaired by the shop or at the dealer care of the CPO warranty.
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    did u take it to the dealer or a private shop? Keep us posted on what it was..
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Aug 06 2014
    California
    I took it to a Indy shop because the dealer wasn't too close and wanted to avoid the hefty toe charge. Here's an email I received from the shop
    7119 - cylinder 4 P0304 00 096 misfire detected- intermittent
    7123 - cylinder 6 P0306 00 096 misfire detected - intermittent
    7121 - cylinder 5 P0305 00 096 misfire detected - intermittent
    6371 - random multiple cylinder misfire detected P0300 00 096 - intermittent
    6238 - fuel rail/system pressure P0087 00 101 Too low
    6183 - low pressure fuel regulation P310B 00 101 fuel pressure outside specification
    6208 - fuel trim; bank 1(mult) P1128 00 096 system too lean - intermittent
    Senior Member Two Rings jcdeng's Avatar
    Jan 04 2016
    2013 S4 DSG 2017 G63
    carbon cleaning?
    2013 S4 prestige S-tronic, APR STG II with TCU tune, AMS Alpha cooler, ECS intake, Milltek Valvesonic, ECS skid plate, CR-15, RS4 front bumper, 034 X-brace, 034 RSB, KW V2, ONEighty custom headlights, custom 19" Work Emotion CR ultimate. Brembo 380mm front, ECS 2 piece rear.
    Mar 07 2015
    Ottawa, Ontario
    Fuel pump, fuel pressure regulator, fuel sensor, etc.
    Seems like it's fuel related.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I'd have them check the fuel pump first which should be easy to do... seems fuel related for sure.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Quote Originally Posted by MrFunk View Post
    +1
    My bet is on fuel pump
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Aug 06 2014
    California
    If it is the fuel pump should I upgrade? Any ideas...
    Aug 03 2014
    Queens
    Quote Originally Posted by Michaelds4 View Post
    I'm talking about the low pressure fuel pump in the gas tank, no upgrade there.
    Previous
    Nov 19 2011
    Rhode Island
    yeah this is def a fuel pump issue. Haven't heard to many issues on here about fuel pumps? Do u have to drop the tank to get it out? I would to confirm spray some started fluid in the intake and see if it still runs.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    You know there was a recall for the fuel rail on 2010's right? My bet is the high pressure fuel pump with my second choice choice being the in tank pump. But definetly get that fuel rail replaced asap.
    Aug 03 2014
    Queens
    Quote Originally Posted by dizzlesizzle View Post
    Access to the lpfp is under the rear seats. Unscrew the union nut and pretty much go from there.
    Agreed with the recall.. If you haven't got it done, get the updated rails.
    Previous
    Aug 08 2008
    2017 Q5
    Houston, TX
    here is a link to the recalls for the model lines.
    http://www.edmunds.com/recalls/audi.html
    __________________________________________________ ____________________________
    2016 Aud S7 - Massaging Seats are pretty neat
    2013 VW Passat TDI - Black - sold
    2015 S4 Prestige - DSG - Mythos Black Metallic 2003 Civic EX 5spd - Gone
    2010 F-150 Lariat Super Crew - Gone 1988 Toyota Supra N/A 5spd - Gone
    2008 A4 2.0T 6spd - Gone 1999 Civic EX auto - Gone
    UTSA Alumnus - #BIRDSUP #WBC #GETROWDY
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by kcobourn View Post
    If your belt shredded your crank pulley is most likely toast.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Nov 19 2011
    Rhode Island
    Quote Originally Posted by agorich View Post
    The recall states its only for 11-12 not the 2010?
    Aug 08 2008
    2017 Q5
    Houston, TX
    yeah. I'd suggest calling 1-800-822-2834 and give them your VIN and they can check if there are any outstanding recalls for your car and if it has any extended warranties for known issues. I did this last night around 2am central US time I think and they were able to let me know my car had no issues w/ the airbag in a matter of a minute or less. Great piece of mind for anyone that may have purchased used or is thinking of doing so.
    Jan 14 2009
    pasadena md
    Also even easier. You can go onto audiusa.com and check for open recalls with your vin as well.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    either fuel pump or fuel pump control module
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Mar 07 2015
    Ottawa, Ontario
    Any update?
    Jan 04 2013
    2008 Acura MDX
    United States
    Quote Originally Posted by infinkc View Post
    You're correct that's the issue - now it's at the dealer under CPO repair. Hopefully this one lasts 50k+ with the APR pulley.
    Aug 06 2014
    California
    Got the car back today. Low pressure fuel pump. They believe it was from the change of seasonal gas. Who knows 500 dollars later can't complain too much
    Nov 19 2011
    Rhode Island
    what octane have u been using?
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    how would changing gas mess up the pump? Unless there was a bunch of junk in the fuel and if that was the case I would be checking the fuel filters as well.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Mar 07 2015
    Ottawa, Ontario
    "They believe it was from the change of seasonal gas"? Sounds odd to me.
    So how did they come to that conclusion?
    Nov 19 2011
    Rhode Island
    but what is so different between gasses that a pump can "understand". it just keeps pumping regardless. it would have to be clogged and over worked and burned out.
    Aug 06 2014
    California
    Always 91 highest we have in Bay Area besides occasional 85. Didn't ask too many questions since I orginally was quoted almost 1k
