Results 1 to 16 of 16
    Nov 30 2015
    Goochland VA
    Wheel treatment for brake dust
    I did a search under "brake dust" and didn't find the answer I was looking for so here goes:
    Short of replacing the stock brake pads, is there any kind of wheel treament you are applying to the wheels that makes cleaning them that much easier? If so, does it work well and would you highly recommend it?
    Mar 11 2015
    DE
    Armorall wheel protectant works surprisingly well. Or you could always wax/seal your wheel.
    2013 P+ | DSG | SD | BO | Carbon Atlas | MMI/NAV | Nappa Leather | Supercharged Badges
    AWE Touring with Res DP Exhaust | H&R Spacers | Passport Escort 9500ix + Blendmount | Weathertech Liners | AWE S-FLO | H&R Sport Springs | EC Alu Kreuz | Forgestar CF10 | EPL Stage 2
    Jul 10 2015
    You could use Opti-coat on your wheels. Do a Google search on it and you can see for yourself.
    Aug 30 2013
    KY
    +1 on the Armor All stuff. It's cheap and you just spray it on clean rims.
    SLOWER TRAFFIC KEEP RIGHT
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    wax them. but your better of just changing the pads...cheap enough to do.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by dizzlesizzle View Post
    This.
    Poor Boys Wheel Sealant works as good as it smells. I'm also waiting for a set of Akebono's to be delivered any day now, to use with my summer wheels.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Replace with ceramic pads. 1st thing I did when I bought the car... otherwise you will be cleaning them a lot - even if you treat them.
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Quote Originally Posted by milesed View Post
    +2 Amazing stuff.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Senior Member Three Rings sc117's Avatar
    May 11 2015
    2015 Audi SQ5
    NOVA
    Quote Originally Posted by bizzy View Post
    +1
    I also got the whole car Opti-Coated
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Best thing to do is use a ceramic coating of some sort. Remove the wheels, polish them to new condition and remove 100% of the contaminants. Wolfgang Uber Ceramic Coating is one of the best and certainly the most simple to apply and use. Great stuff. Pinnacle Black Label Wheel Coating and DP Wheel Coating are some of the easiest coatings to use too. Sonax polymer net shield is another great one. G-techniq Wheel Armor is not one I've used personally but some folks I know swear by it.
    Waxes and standard sealants won't hold up to the heat very well and will eventually evaporate away.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by MrFunk View Post
    Plus you will get the added benefit of no longer having brake squeal. Best thing I ever did on my s4s. Alternatively, paint your wheels black.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by Eggrollz4u View Post
    Armoall FTW this is what i use. Its easy and quick. And you can get it anywhere.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    AWP (ArmorAll Wheel Protectant) ironically really is the best. I don't use the other stuff they make but that AWP is amazing. Just be careful not to get the other ArmorAll wheel cleaner stuff. Get AWP
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Active Member Two Rings alhale's Avatar
    Oct 31 2011
    Lingenfelter Corvette C4
    Rockwall, TX
    +1
    I tried a lot of things to eliminate the brake dust from my wheels. The absolute best thing I ever did was Akebono pads! Much smoother in stop and go traffic and very little dust (almost none compared to the OEM pads).
    2010 S4 DSG Ext: Phantom Black Pearl Int: Black/Pearl Silver -Unitronic Stage 2+,19" A7 wheels Black powder coated, Roc-Euro intake, 034 Solid motor Mounts, 034 Trans mount, Apikol Diff mount, Akebono Pads, and a few Ross-Tech tweaks.
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Agree changing pads is best to reduce the dust. opticoated mine and while easier to clean, the dust builds up just as quick as before.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Established Member Two Rings nickskeeta's Avatar
    Nov 30 2014
    Hollister, Ca
    Ceramic Pro, Ive had my whole car coated with it
    @nickskeeta
    2011 S4 6MT Meteor Gray Pearl
    2018 Silverado 6.2 LTZ
